Controls, Steering, and Trim Tabs
Teleflex Seastar Leak in Cold Wx
Topic: Teleflex Seastar Leak in Cold Wx (Read 1149 times)
November 21, 2012, 08:27:32 AM
Read 1149 times
dxs217
November 21, 2012, 08:27:32 AM »
Problem: After a cold night, the engine (originally raised and centered) is flopped to one side and hydro fluid is pooled in the engine well.
It does not leak at all during spring/summer/fall months (warmer temps).
Now I turn the wheel fully in one direction when I park the boat, this minimizes the leak (still a little bit of a leak though).
Anyone seen this before? I can't isolate where the leak is coming from and why. Seals?
Again, only leaks when temps below mid forties...
1999 215DC
Evinrude 200 FICHT
November 21, 2012, 08:55:51 AM
Re: Teleflex Seastar Leak in Cold Wx
November 21, 2012, 08:55:51 AM »
Run your fingers around the bottom of the cylinder on both sides. My guess is that is where it is leaking from. Here is the seal kit,
http://www.teleflexmarine.com/wp-conten ... 0720-E.pdf
November 21, 2012, 08:58:30 AM
pigbike
November 21, 2012, 08:58:30 AM »
Sounds like a bad seal that hardens up in cool weather to me. Maybe by moving the engine you decrease any pressure in the line. You might need to buy a new seal or seals for you unit.
Someone will come along with a good answer for you, as mine is only a guess.
Blue Agave came up with the answer while I was typing
November 21, 2012, 09:18:41 AM
Mechanical Master
November 21, 2012, 09:18:41 AM »
I don't want to get into your personal life, but I think you've blown a seal...
Get the seal repair kit and your leak should go away.
http://www.youtube.com/watch?v=Iwey31AvAs0
November 21, 2012, 10:27:27 AM
November 21, 2012, 10:27:27 AM »
I just recently installed did the seal kit on mine. Easy to do and it stopped the annoying drip and oil in he splashwell. This will give you a chance to flush out the system and clean and grease the tilt tube and related parts which should be done anyways.
November 21, 2012, 01:26:25 PM
Rigging Master
November 21, 2012, 01:26:25 PM »
Definitely the end gland seals. Buy the replacement kit (includes new end caps), I'll send you the spanner wrench to use, saves you about 1/2 on the cost. You just have to send it back. I have 2 of them...
November 21, 2012, 01:53:53 PM
November 21, 2012, 01:53:53 PM »
Once you have a set of end caps it would be easy to take your old ones to a hydraulic shop for o-rings and seals the next time around.
November 21, 2012, 03:46:28 PM
dxs217
November 21, 2012, 03:46:28 PM »
Thanks guys. Awesome.
I'll order seal kit and wrench (seabob thanks for offer but I'll need one anyway).
1999 215DC
Evinrude 200 FICHT
