Author Topic: HELP! - fuel sender issue found..... :(  (Read 1533 times)
September 03, 2012, 07:13:01 PM
kraw2
Re: HELP! - fuel sender issue found..... :(
« Reply #15 on: September 03, 2012, 07:13:01 PM »
I think this is a poly tank by looking closely. It this correct??
September 03, 2012, 07:48:13 PM
gman 82 aquasport
« Reply #16 on: September 03, 2012, 07:48:13 PM »
I can't tell by looking, I thought I saw what looked like a welded bung to the upper right of the sending unit, but i have been wrong twice today allready so it could be 3 times :?
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
September 04, 2012, 10:37:29 AM
Georgie
« Reply #17 on: September 04, 2012, 10:37:29 AM »
Since you're not working with an aluminum tank, you're probably in much better shape than most of us who've struggled with our metal tanks.  Should be much easier/safer to remove the screws/fittings from the poly, though I personally haven't worked on one.  Regarding replacement gauge, the WEMA's are definitely the chit!  much more durable and reliable, and supposedly more accurate as well.  Only way to be 100% sure you order the correct gauge though is to pull the existing one out and measure the depth of the tank manually (ruler, stick, etc.) since you likely can't even guarantee the one in there is the correct gauge to be matched.  Would give you a chance to check the bottom of your tank for "gunk" too.  Then you can order with confidence any pretty much any gauge you want that's 1" shorter than the depth of your tank.  Definitely take some time to clean  up the pickup fitting and see how bad she really is.  The guys are probably right in saying it should be replaced too.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
