I thought I would put this out for those who may be interested. I just sent Mark SR a Lexan Dash panel for his Osprey, I had an extra one that I was going to install on mine, but current one is OK, and he is redoing his gauge panel. A couple tips when drilling these, either LEXAN or Plexiglass, using a "plastic Drill Bit" helps prevent cracking because of the different angle of the flukes
http://www.rplastics.com/plasticdrill.html Also, I use a little rubbing alcohol as a cooling agent, like you would use cutting oil on a hard steel when drilling, this works very well when using the hole saw to cut the large holes. Leave the protective paper coating on until finished working with the panel, or if drilling one that the paper has been removed, I would put the blue 3M painter's tape on both sides of the panel where drilling will be done, this helps prevent chipping as the bit/s exit the material.
