Install doesn't look bad but how long does it take to remove the old rusted components? Also curious on what methods you guys used. Is penetrating oil and a breaker bar enough or did you have to use a torch and heat up the nuts? Or did you even have to cut some bolts?
I just did my brakes recently and the most time consuming and annoying part was removing the old rusted components so that's why I ask!
Required Tools: RBFH, Sawsall with top quality Bi-metal blades, Oxy-Acetalene rig is nice if you have ne or can get your hands on it. Oh, and a big pair of vise grips to hold the big punch while you wail on it with the RBFH
If it's not a rusted glob of Shitz, then an impact gun works great on the bolts and nuts, takes em' or breaks em, one way or the other.
