Aquasport Discussion
Woody Non-skid Wax
Topic: Woody Non-skid Wax (Read 611 times)
September 09, 2011, 10:49:48 PM
Read 611 times
Woody Non-skid Wax
September 09, 2011, 10:49:48 PM »
I know that this product works great on brightwork, but I was interested in knowing if anyone has used it on their non-skid? If so how did you like it? Slippery?
September 09, 2011, 11:08:41 PM
Re: Woody Non-skid Wax
September 09, 2011, 11:08:41 PM »
Blue,I have used it on non skid,not slippery if used as directed,use sparingly,spread on a wet deck with a brush,the starbrite deck wash is a good product too.the "secret" with the starbright is to wet deck,squirt cleaner,scrub in,let sit for 10-15 min,scrub again and rinse,it has teflon in it and helps repel stains.
2003 Osprey 225
September 10, 2011, 12:16:29 AM
September 10, 2011, 12:16:29 AM »
Pete which one did you like better?
September 10, 2011, 11:45:06 AM
icemanbryan
Guest
September 10, 2011, 11:45:06 AM »
I like Woodys wax, if you do it right works great
September 11, 2011, 10:15:49 PM
September 11, 2011, 10:15:49 PM »
Anybody else with an opinion?
September 12, 2011, 10:09:18 AM
c master
September 12, 2011, 10:09:18 AM »
Somewhere along the line I saw a comment on here about Penetrol on non-skid decks. I found some at the hardware store and tried it. When I first wiped it on a 'test' area, it seemed oily and I was worried about it being slippery but it 'dried' (or absorbed). Actually I think the floor is grippier now, and it comes clean with a hard spray of water. I have a '75 with the original deck (light gray-greenish). The only way I can describe it is, it seemed to make the fiberglass look "alive" again...a little better color, a little shinier.
Very easy to apply...I cleaned the deck first, then just used an old rag to wipe the Penetrol on. I can do the whole deck in about 15 minutes. Also very inexpensive...I have Woody Wax but I use it for the metal, engine cover, etc.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
September 12, 2011, 10:40:50 AM
icemanbryan
Guest
September 12, 2011, 10:40:50 AM »
I like woodys wax too.
But like he said, use as directed.
A little goes a long way
Woody Non-skid Wax
