Author Topic: Front Bunks  (Read 1194 times)
September 11, 2011, 09:32:43 AM
Read 1194 times
Front Bunks
« on: September 11, 2011, 09:32:43 AM »
Before I dropped the 222 in for the first time I decided to change the structure of the trailer supports. Before it had 7 keel rollers and 4 back bunks. I have been looking at other trailers over the past few years and really like the addition of front swivel bunks to help with lining the hull on the trailer when loading and unloading. I found a trailer manufacturer in Reddick FL that had actually built the trailer for the 19-6. I called him and talked about options that he offered compared to the really thin and cheap looking swivel brackets that you find at most marine supply stores. I wanted something more substantial and better built. He does sell the parts he uses on his trailers to the public so I ordered four of the brackets and 4 10" rollers.
He sells the 12" brackets with swivel and all of the u-bolts and washers and locknuts (basically everything you need to attach them) for around $32.00 each. The 10" rollers with the shaft and pal nuts ran $15.00 each. These rollers are not the black rubber ones but they are the poly ones just not made by Stolz.
I thought this was really good deal especially for the brackets which up here anyway are hard to find.
If you are interested in adding these to your trailer I highly recommend you give B&S Trailer a call. Cliff the owner is a really nice guy and a pleasure to work with.
I have no affiliation with them other than being a satisfied customer!
Their number is 352-591-2161 ask for Cliff.
This what my install looks like.
September 11, 2011, 11:34:16 AM
Re: Front Bunks
« Reply #1 on: September 11, 2011, 11:34:16 AM »
Thanks Lewis.  Good looking brackets.  It's about time to replace some of my bunk brackets.   :thumright:
September 11, 2011, 02:32:07 PM
Re: Front Bunks
« Reply #2 on: September 11, 2011, 02:32:07 PM »
That came out great  :thumright:
September 19, 2011, 04:55:55 PM
kedd
Re: Front Bunks
« Reply #3 on: September 19, 2011, 04:55:55 PM »
Slvrlng
I'm looking to add the same type set to my trailer.
Do you have a pic of the trailer without the boat?
Kedd
September 19, 2011, 05:01:28 PM
Re: Front Bunks
« Reply #4 on: September 19, 2011, 05:01:28 PM »
Man I need a set of those for my trailer!  Hard to see on my work computer though..  the pics are a tad dark.
September 22, 2011, 11:35:09 AM
Re: Front Bunks
« Reply #5 on: September 22, 2011, 11:35:09 AM »
I do not have a pic of just the trailer yet. I will try to get one this weekend. Sorry the pics are a little dark, I'll try to get some better ones, those are off my phone.
September 22, 2011, 01:26:05 PM
Re: Front Bunks
« Reply #6 on: September 22, 2011, 01:26:05 PM »
Quote from: "slvrlng"
Good luck with that Wing.  :roll:
If I didn't know better, I would have thought Gran posted this. :wink:
September 27, 2011, 08:49:33 AM
Re: Front Bunks
« Reply #7 on: September 27, 2011, 08:49:33 AM »
Here are some more pics of the setup on the trailer.
These are the rear bunks, two on edge and two flat, both are 2X6 PT.
This is the setup for the new front ones. Wider towards the stern and narrower towards the bow. The front supports are about a foot apart making the bunks about 4 inches apart so the keel slides in every time. The rear supports are about 30 inches apart.
