Aquasport Discussion
Rear Seat for Aquasport 205 osprey
Topic: Rear Seat for Aquasport 205 osprey (Read 987 times)
July 29, 2011, 10:18:40 PM
Read 987 times
Dirtball
July 29, 2011, 10:18:40 PM »
Hi Guys,
Does anyone knwo where I can get rear seats from, for osprey 205 centre console.
Much appreciated
July 29, 2011, 10:25:24 PM
Re: Rear Seat for Aquasport 205 osprey
July 29, 2011, 10:25:24 PM »
Hey DB,I have not seen much in the line of original seating,its very hit or miss,the best way to get what you want is to get a local marine upolstery shop to make you some,how ever that will probably not be cheap,you may also find some aftermarket seats that may work.check some on line sources to see whats available,it may help if you post a pic of the area you want seats for
2003 Osprey 225
July 30, 2011, 09:18:21 AM
Rigging Master
July 30, 2011, 09:18:21 AM »
To be honest with you, DB, I can't ever remember aft seating on the 205 or her twin sister, the WC 210CCF...
I'd go with what Pete suggested. Probably be as much to ship them over there as they would cost...
July 30, 2011, 08:43:51 PM
plugger
July 30, 2011, 08:43:51 PM »
As a 205 owner i can verify there were two what i call jump seats that attach in each rear corner. They are large and heavy and take up a lot of room, once installed you loose access to the transom door on one side and to the battery switch on the other.
Not practical at all
