Paints, topsides and bottom and Gelcoat Topics
Peel Away stripper on my 22-2
Topic: Peel Away stripper on my 22-2 (Read 5381 times)
January 01, 2007, 06:09:38 PM
Reply #15 on:
January 01, 2007, 06:09:38 PM »
I tried saran wrap with the Interlux stripper. It did help prevent drying out but it was a PITA to get it in place. A helper would come in handy there.
Jim, I have not found anything that looks like a repair. I still have not tackled the area between the bunks but that is the best looking area of the entire hull. Between rain and company I haven't had one thought about crawling back under the boat. The last ones left about 30 minutes ago. Damn, what is that I hear? Oh yeah, it's
SILENCE.
January 01, 2007, 06:51:50 PM
Reply #16 on:
January 01, 2007, 06:51:50 PM »
Sit back, pour yourself an adult beverage of your choice, forget the boat for now and enjoy the quiet.
January 13, 2007, 06:21:24 PM
Reply #17 on:
January 13, 2007, 06:21:24 PM »
A little more info. I was digging around in my shed for something and found this roll of some type of plastic membrane. It was left here by the previous owner and I thought it might come in handy for something. I assume it's some type of construction moisture barrier. It's about 12" wide. It's sort of like cellophane but with the thickness of a good visquene or whatever they call it now but stiffer. Last Saturday I put some Peel Away on about 1 sq. ft. of thick bottom paint. I used some of plastic membrane instead of the Peel Away paper. I totally forgot about it until today. When I pulled the plastic off, the Peel Away was still wet and several big chunks of the bottom paint actually came off with the plastic. I hit the rest of it with a scraper and the bottom paint actually came off pretty easily, right down to the gelcoat. The gelcoat did not appear to have softened. I actually have a smooth, albeit stained, bottom in that spot.
1- plastic works as good or better than paper.
2 - 48 hours isn't long enough for the Peel Away to work on bottom paint.
3 - 7 days doesn't appear to hurt the gelcoat.
4 - It's still going to be a lot of work.
January 13, 2007, 08:26:45 PM
Reply #18 on:
January 13, 2007, 08:26:45 PM »
Can you find any marking on the rolls that says what the stuff is?
January 14, 2007, 07:24:03 AM
Reply #19 on:
January 14, 2007, 07:24:03 AM »
When I left mine on for 7 days, seems where the sun had dried it out, the paint had to be chipped off - the peelaway seemed to be still gooey but didn't phase the paint. The chine area of this 230 has a groove like indentation just inward of the chine/side area and there, the sun didn't get and the peelaway was on thicker - that seemed to peel away with the putty knife. I never got anything to come off with the paper. Tomorrow morning I drag her up to the sand blaster. I'm going to have the bottom repainted, hopefully with a hard paint that will last forever. Is there such a thing, if the boat lives on the trailer and the boat will probably never stay in the water more than a week?
January 14, 2007, 07:38:44 AM
Reply #20 on:
January 14, 2007, 07:38:44 AM »
Jim, no markings. I'll try to remember to take and post a pic later. I have not had my coffee yet.
Rick, I hate to recommend a paint. Maybe wart or another pro will chime in. I'm looking at Awlgrip or Imron. $$$$$
January 14, 2007, 06:10:45 PM
Reply #21 on:
January 14, 2007, 06:10:45 PM »
I measure this as 0.005" thick. No markings.
January 14, 2007, 06:17:30 PM
Reply #22 on:
January 14, 2007, 06:17:30 PM »
If the plastic isn't stretchy like poly sheeting and feels hard, I'd guess it was Mylar. Looks like about 500 feet.
January 14, 2007, 10:25:09 PM
Reply #23 on:
January 14, 2007, 10:25:09 PM »
Yep, no stretch. Hard glossy surface.
January 14, 2007, 10:33:54 PM
Reply #24 on:
January 14, 2007, 10:33:54 PM »
Mylar.
January 21, 2007, 08:55:18 PM
Reply #25 on:
January 21, 2007, 08:55:18 PM »
Last Saturday, I applied Peel Away to the front half of the hull again. I was out of paper so I used the mylar film. I was determined for this to work this time. I let it sit seven days (against manuf. recommendations) with good and bad results. Saturday I peeled the mylar off and started scraping. I probably got 90% of the paint this time. Where it was really thick there was still some paint left but determined scraping got most of that too. Now the bad. In a few small spots, the Peel Away damaged the gel coat. If I added up all the small areas, there is probably 1 sq ft with NO gelcoat now and 2 sq ft that the gelcoat had pinhead size blisters. I hit it with the pressure washer and the blistered places peeled off leaving what looks like a good layer of gelcoat? Maybe these were repaired areas? Oh well, I'm just going to skim the bad places with thickened epoxy.
I wonder if I can call Peel Away and get a refund.
January 22, 2007, 05:32:18 AM
Reply #26 on:
January 22, 2007, 05:32:18 AM »
The guy that let me into Fiberglass Services is a restoration guy ("breathin' fiberglass for 18 years") and I told him of my peel-away experience and he chuckled and said "yup, that stuff don't work".
January 22, 2007, 08:03:30 AM
Reply #27 on:
January 22, 2007, 08:03:30 AM »
Did he mention what
does
work?
January 22, 2007, 07:12:06 PM
Reply #28 on:
January 22, 2007, 07:12:06 PM »
I mentioned that I should have checked there to see if they knew anyone that did bottom paint removal and he said "that would be me and I hate removing bottom paint" (popular feeling
) As for the stripper, he mentioned that there are "a few new ones out" - didn't mention names and didn't say which worked. Sorry.
