Author Topic: rudder ports for 29 '  (Read 1073 times)
March 08, 2011, 07:59:54 PM
Read 1073 times
takeoff29
« on: March 08, 2011, 07:59:54 PM »
looking to buy two 1 1/4" id square base top side mount rudder ports with packing nut for a 29 aquasport.any info would be helpful thank you.  8)
March 08, 2011, 08:01:35 PM
takeoff29
Re: rudder ports for 29 '
« Reply #1 on: March 08, 2011, 08:01:35 PM »
or any info as to what brand they used, the year is a 1982 29 aquasport
March 09, 2011, 12:05:58 AM
« Reply #2 on: March 09, 2011, 12:05:58 AM »
I would say Buck Algonquin was probably the vendor.  We used them on Stamas I/Bs, give them a call.  If they weren't the supplier, they can probably set you up with a close match...
March 10, 2011, 06:35:00 PM
takeoff29
« Reply #3 on: March 10, 2011, 06:35:00 PM »
i glass beaded my port and found they were made by PERKO but i don't think they make them any more .cannot find any info on them from perko .I may end up with the buck algonquin and mod. them if i cannot find direct replacments thank you seebob4  :D
March 10, 2011, 07:05:58 PM
« Reply #4 on: March 10, 2011, 07:05:58 PM »
takeoff,
Should you have to mod, keep in mind bronze is difficult to cut, you need sharp blades, best done on a band saw...
March 13, 2011, 08:22:52 PM
takeoff29
« Reply #5 on: March 13, 2011, 08:22:52 PM »
thanks for the info seebob4  :?
