Author Topic: Osprey 205 Kicker  (Read 2222 times)
July 28, 2010, 12:21:03 AM
Read 2222 times
CaptBurt
Osprey 205 Kicker
« on: July 28, 2010, 12:21:03 AM »
I just bought a 2000 Osprey 205 with a 200hp Johnson.  I will be fishing offshore near St Augustine, FL.  I would like any info on the size of a kicker motor for trolling/get home.  I am thinking about 15hp 4 stroke long shaft.  Any suggesdtions?
Capt Burt
July 28, 2010, 06:01:21 AM
Re: Osprey 205 Kicker
« Reply #1 on: July 28, 2010, 06:01:21 AM »
Hey CaptBurt,
Do you ever fish out of Matanzas? I`m down in Palm Coast.
July 28, 2010, 08:05:53 AM
« Reply #2 on: July 28, 2010, 08:05:53 AM »
My suggestion would be tow boat coverage and a good radio.
July 28, 2010, 10:20:42 PM
« Reply #3 on: July 28, 2010, 10:20:42 PM »
Anything 8 HP and above would be fine.  There are some nice 9.9s out there...
July 28, 2010, 11:01:18 PM
« Reply #4 on: July 28, 2010, 11:01:18 PM »
Quote from: "CaptBurt"
Capt Burt
Welcome aboard,i have a 15hp short shaft Yamaha 4 stroke on a adjustable bracket,keeps the motor totally out of the water when not in use, and it will push my 225 Explorer at 7 mph loaded up with offshore gear,i also have sea tow.
July 29, 2010, 12:17:21 AM
CaptBurt
« Reply #5 on: July 29, 2010, 12:17:21 AM »
Quote from: "fitz73222"
Hey CaptBurt,
Fitz;  I will be fishing out of Palm Coast;  bought a home there and will be there full time later this year.  Will bring the boat in Sept.  Have been running Matanzas in friends 16' Polar, but plan more offshore fishing when I get the Osprey there.
CaptBurt
July 29, 2010, 12:18:46 AM
CaptBurt
« Reply #6 on: July 29, 2010, 12:18:46 AM »
Quote from: "John Jones"
Thanks JJ; I have both.
CaptBurt
July 29, 2010, 12:22:23 AM
CaptBurt
« Reply #7 on: July 29, 2010, 12:22:23 AM »
Quote from: "GoneFission"
Capt'n John;  Was considering a 9.9 but would like to troll at 8 to 8.5 Knots.  When I do that with my main power, I'm pushing lots of water.  You think the 9.9 is OK?
CaptBurt
July 29, 2010, 12:27:44 AM
CaptBurt
« Reply #8 on: July 29, 2010, 12:27:44 AM »
Quote from: "Circle Hooked"
Capt Burt
Thanks, CH.  I plan to tie the kicker to the Johnson as my autopilot will then steer when I'm trolling.  Would never be without Vessel Assist (Sea Tow).
CaptBurt
July 29, 2010, 02:04:24 AM
labboss2003
« Reply #9 on: July 29, 2010, 02:04:24 AM »
guess i should have read this post before i posted mine :oops:
August 26, 2010, 08:27:00 AM
ReelTimeWes
« Reply #10 on: August 26, 2010, 08:27:00 AM »
I have a Yamaha T8 on my 205 Osprey. I use it for trolling on Lake Erie but we slow troll from 1.5 to 3 mph. I have it mounted on an aluminum jack plate. It has power trim and it's fully controlled from the helm.  Steering is tied right into the main motor. Works like a charm. Pushes the boat at 9 to 10 mph at W.O.T. Picture was before steering linkage was installed.
1998 Aquasport 205 Osprey
August 26, 2010, 12:05:08 PM
« Reply #11 on: August 26, 2010, 12:05:08 PM »
CaptBurt
I think a 9.9 will get you 8-10 KT, but like all other outboards, you've got to have it propped right.  A large diameter, low pitch prop will work best, and it may take a little trial and error to get it just right.  You might PM Reel Time Wes and see what prop he is running....  :wink:
