Marc,Simply filling a bare hull with foam is not going to provide that hull integrity. They also need bulkheads between those stringers to provide torsional stiffness...
Indeed an interesting build process. The "squares", as Rick pointed out, would appear to me to reduce the size of unsupported panels, the area between bulkheads and/or stringers.I'm sure other builders would be able to mimic this process, although the molds would have to be modified to ensure they could be clamped together, and the amount of foam pumped in would have to be carefully regulated and pre-determined through numerous tests, as we all know that when foam is expanding, it needs somewhere to go, and if the space it is occupying is filled before the expansion process is complete, something is gotta give...I've been a member over on Continuous Wave for several years now, one of the biggest problems with older Whalers is water intrusion and absorption into the foam, creating undesirable weight gain without any way to get rid of it. That, the problem of lack of in-sole storage (due to all that foam), and the price says to me that I'll take an AS ANYDAY!
