Author Topic: Trailer?  (Read 1233 times)
February 09, 2006, 11:31:48 PM
Read 1233 times
22FamilyFish
Trailer?
« on: February 09, 2006, 11:31:48 PM »
My '79 Aquasport 22-2 Family Fish(O/B FFV) is sitting on an older Shoreline single axle trailer.I'm looking to replace this trailer with maybe a Venture tandem axle w/brakes.The info plate on the trailer is not legible so I have no idea as to the GVWR.Can anyone who has a similar size boat please give me some info(GVWR) off thier trailer?
I would get it weighed but it's off the road(not roadworthy) :roll: .Thanks.
February 10, 2006, 01:26:26 PM
Trailer
« Reply #1 on: February 10, 2006, 01:26:26 PM »
My 222CCP weighs in at about 4000 lbs with fuel, so I went with a 5600 lb dual axle trailer.  Venture makes a 4700 that would suit your needs well.  You definately want brakes - many states require them now for trailers that gross over 3000#!  Surge-powered discs are the way to go - drums rust up and are a pain...
I was able to find a deal on a quality RoadKing trailer with Capps Trailers - you can check them out at:
http://www.cappspromotions.com/instock_ ... ailers.asp
There are also a couple dealers who have some good deals on ebay:
http://cgi.ebay.com/ebaymotors/boat-tra ... dZViewItem
http://cgi.ebay.com/ebaymotors/2006-Ven ... enameZWDVW
Good luck!
February 10, 2006, 11:46:47 PM
Bill
« Reply #2 on: February 10, 2006, 11:46:47 PM »
22FamilyFish, I've got an '88 222 Express Fisherman (single 200hp ob), which I think is very much like your model. GoneFission mentioned the Venture 4700 --- I bought a new Venture bunk 4700 (they also make a 4700 roller) about 4 years back and have been very pleased with it. It's a tandem rig with drum brakes on the front axle (torsion axles), 14" tires. I usually make 2-3 300 mile round trips from northern VA to Ocean City, MD each summer, and I've towed the boat down to Tampa and back -- so far the trailer has given me no problems - to include the drum brakes, but that may be because I don't get to dunk the rig in saltwater nearly as often as I'd like to.
Bill
Shark Shadow
February 16, 2006, 09:55:47 PM
22FamilyFish
« Reply #3 on: February 16, 2006, 09:55:47 PM »
Thank you both for your response.I called my nearest Venture dealer and got some prices today on the 4700 and 5000.It's available in aluminum as well.Thanks. :D
