Excessive steaming to me would indicate warmer exhaust gasses than usual. And the vibration...hmmm, given that you haven't grounded the boat as of late and maybe bent a prop shaft or tweaked a strut, those, with the oil pressure, says something is amiss in the starboard motor. Realizing oil pressures will start high, then come down after warm-up.Just my 2 pennies, but the starboard motor doesn't sound good...and we can't even hear it!
Anthony,Let's look at the basics first. Do the oil pressure gauges for both motors react the same at initial start up, then only the port comes down to 40? Does the starboard fluctuate at all, given load, speed, what have you? Could be a sender or gauge if it goes to 80 and stays, like it's frozen.Vibration. If it ain't to much of a beeetch, remove the coupling bolts at the tranny output flange, pull the shaft back, then bring it back in and see what your clearances are. I used to align (at Stamas) to .0025", but .004 will do you fine. Maybe something got out of whack just a smidge and is causing a bit of mis-alignment, hence the vibration. Good time to re-pack the stuffing boxes if they haven't been done in a bit...Are your motors FWC? What are the temp gauges doing in relation to each other? Do they start out the same then the starboard motor starts to climb way quicker than port?And what condition are the elbows and risers?
