Author Topic: OMC Stearn Drives  (Read 572 times)
August 30, 2009, 06:49:57 PM
Read 572 times
Mark Sr
OMC Stearn Drives
« on: August 30, 2009, 06:49:57 PM »
For the guys that restore A.S. with a stearn drive,do you keep the OMC or do you swap them out for a Mercruiser or Outboards? The outdrive I have in question is the stringer with the electric shift. What are your Pro's & Con's? Do you like them etc? I know that they are very costly to repair. If you switch to a outboard does it upset the balance with all the weight from an inboard.
Thanks in advance
Mark Sr
Mark Sr
August 30, 2009, 11:05:02 PM
Hardwater
Re: OMC Stearn Drives
« Reply #1 on: August 30, 2009, 11:05:02 PM »
Hi Mark,
Here's a link to a discussion about older OMC stern drives pros/cons.  It starts out as a topic related to Evinrude boats, but about half way through it gets into fairly detailed information on stringer mount OMC stern drives in general...and their application on wood stringers in the Evinrude hulls specifically.  Not familiar with the application of these outdrives on AS hulls, but there may be some general info that's useful - others here may have even more information.
http://continuouswave.com/ubb/Forum1/HTML/013661.html
\'86 222 CCP
\'88 Mercury 200hp Black Max
August 31, 2009, 10:54:55 PM
« Reply #2 on: August 31, 2009, 10:54:55 PM »
I know a bunch of folks who have gone from I/O to outboard with no problems (albeit not your model).  Depending on your motor, an outboard should be less weight - which helps to offset the placement.
September 01, 2009, 10:22:57 AM
Mark Sr
« Reply #3 on: September 01, 2009, 10:22:57 AM »
Do the guys that have the electric shift still use them. That would be the stringer outdrive not the cobra. Do you like to keep the boat as original as possible? What's the difference between the OMC 400 or 800 electric shift stearndrives.
Mark Sr
September 21, 2009, 10:35:01 PM
bdtsr
« Reply #4 on: September 21, 2009, 10:35:01 PM »
Parts for most OMC drives are getting scarce. If you keep it, be carefull of the rubber boot. Between rotting and animals that love to chew on them, your boat could become more of a project then you want. The wires tend to go badin the control box and at the transom. Changing to another drive is not easy as the stringer drive cutout is much larger the any other brand drive. Going to an outboard would be a good thing. Even a newer 4 stroke on a bracket would be lighter than a V8 I/O.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
