Knobs for center console plexiglass doors on CCP
Topic: Knobs for center console plexiglass doors on CCP (Read 1278 times)
June 25, 2009, 08:50:59 AM
Read 1278 times
jdupree
June 25, 2009, 08:50:59 AM »
One of my original knobs on one of the plexiglass doors has broken and need to be replaced as well as the other one. Would I find this kind of thing in the cabinet section of Lowes/Home Depot? I have checked with several marine places and they don't have anything close.
I would like to go with some kind of magnet setup. Has anyone had to replace these? If so, what did you use?
John L. Dupree, III
AQABLA84E999
Member #257
June 27, 2009, 02:03:01 AM
Hardwater
Re: Knobs for center console plexiglass doors on CCP
June 27, 2009, 02:03:01 AM »
j -
This is one of the knobs on the smoked plexiglass 'doors' on the upper console, right? It looks like the twin smoked plexiglass doors on the console of your '81 are either the same - or very similar - to those on my '86.
Do you have a picture? If not, I'll try to post a pic of the hardware on mine later tomorrow. Depending on how they match up, there's a local source that has amazing inventory I can check.
\'86 222 CCP
\'88 Mercury 200hp Black Max
June 27, 2009, 07:47:52 AM
scott_gunn
June 27, 2009, 07:47:52 AM »
I found mine at Boater's World/West Marine. I'm not sure if mine is the same - mine has a round "ball and socket" type of connector - the ball side is attached to the door and the socket is attached to the console. It doesn't work very well, next time I will replace it with something different.
June 29, 2009, 08:29:48 AM
jdupree
June 29, 2009, 08:29:48 AM »
Thanks for the response Hardwater & Scott. Mine is the ball & socket setup. The round knob is mounted to the plexiglass door and slides into the plastic socket mounted on the teak trim where the door closes. Never liked the setup anyway.
I checked west marine and could not find one
Not quite sure what to use for now
John L. Dupree, III
AQABLA84E999
Member #257
June 29, 2009, 08:49:58 AM
allen456
June 29, 2009, 08:49:58 AM »
Get me a picture and I will check with all of my marine hardware suppliers.
1979 Aquasport 200 CCP--1981 Johnson 175
June 29, 2009, 09:08:57 AM
jdupree
June 29, 2009, 09:08:57 AM »
Thanks Allen
Will shoot a picture tonight and post in the morning.
John L. Dupree, III
AQABLA84E999
Member #257
June 30, 2009, 12:13:19 PM
jdupree
June 30, 2009, 12:13:19 PM »
Allen,
This is what I have:
John L. Dupree, III
AQABLA84E999
Member #257
July 01, 2009, 12:03:31 AM
Hardwater
July 01, 2009, 12:03:31 AM »
j-
That is the same latch that's on mine. Here's one source:
http://www.fpmarine.com/Latches%20Locks ... tm#latches
Go to #47 on the latch list for this latch - Perko made - FP Marine part #P1040281:
http://www.fpmarine.com/images-website/P1040281.jpg
$3.75 each.
Here's a direct link to cabinet hardware on Perko's homepage - the ball and socket latch is listed first :
http://gator49.hostgator.com/~zeromyst/ ... th=224_183
Just looking at them, these latches seem to leave a lot of room for improvement. At the same time, the originals on our boats have worked for 20+ years.
\'86 222 CCP
July 01, 2009, 08:18:39 AM
jdupree
July 01, 2009, 08:18:39 AM »
Thanks Hardwater
I don't like those knobs but as you said they did last on my boat almost 30 years. Thanks again :!:
John L. Dupree, III
AQABLA84E999
Member #257
July 01, 2009, 02:27:28 PM
allen456
Reply #9 on:
July 01, 2009, 02:27:28 PM »
John, that is a special order for me and I could only get it for a few cents cheaper with a 1-2 week turn time. Probably would be better off to order from the other site, but let me know if there is anything else that you need me to look for.
July 02, 2009, 09:08:15 AM
jdupree
Reply #10 on:
July 02, 2009, 09:08:15 AM »
Thanks for all the help guys
Looking at those latches, I don't see a knob that would be on the console door to enable you to pull it out
John L. Dupree, III
AQABLA84E999
Member #257
