Author Topic: Hydraulic Trim Tabs  (Read 792 times)
February 21, 2009, 05:59:15 PM
Read 792 times
miamiguy
Hydraulic Trim Tabs
« on: February 21, 2009, 05:59:15 PM »
Does anyone know where the pump is for a 88 250 Express?  Our tabs arnt working and we are going to try to trouble shoot them but im not sure where the pump is.
March 11, 2009, 04:38:31 PM
Hawg Hunter
Re: Hydraulic Trim Tabs
« Reply #1 on: March 11, 2009, 04:38:31 PM »
Mine is near the stern but they were aftermarket ,It was next to the wash down pump
Capt, Richard "DUKE" Bowen
Conyers Ga
1988 290 Aquasport XF
March 11, 2009, 05:55:53 PM
« Reply #2 on: March 11, 2009, 05:55:53 PM »
Mine is in the Starboard closet in the back.
March 17, 2009, 07:57:23 AM
bdtsr
« Reply #3 on: March 17, 2009, 07:57:23 AM »
If they are Bennett tabs, there should be an orange wire feeding the switch assembly. On this wire there is a black fuse holder. Check for a blown fuse and/or corrosion. Also check the harness plug at the pump. If nothing (pump or solenoids) works it's power or ground. You can jump the motor with 12 volts to test as well as the solenoids. You don't have an oil leak do you?
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
