Well maybe it's mounted just a little the port side????? Without spell check, I'm an ... ediot! :)
When you guys talk about the poured transom, what foam are you using? I assume 2 part 8 lb foam from somewhere like FCI?Am I assuming correctly? Is ther ea link to a rebuild where this was done?thanks
I used Nidacore transom pour, FGCI sells Arjay. They are all the same type material, seacast is much more expensive though.
