Author Topic: Midsummer report  (Read 486 times)
August 01, 2008, 04:37:36 PM
Read 486 times
jeff23
Midsummer report
« on: August 01, 2008, 04:37:36 PM »
Hi All--
I've been busy fishing and haven't been back here to post in awhile, thought I'd drop by and let you know how my boat is doing.  I acquired my 1979 170 last fall, put it in the water in June, and have been out in it 2-3 times a week since.  Over the winter the steering cable, which wasn't in good shape to begin with, rusted up and snapped come spring.  Very little else has gone wrong--I put in a new main bilge pump just to be sure.  However, the boat takes on very little or no water while sitting at the dock (previously I had to have the livewell connection capped off--it was taking in small amounts of water that piled up over time).  The fuel tank, which as far as I know is original, also seems fine--I have a Racor filter on it, which I unscrew and check for water periodically.  Otherwise all is well.  The transom has some cracking in the gel coat along the cap, but it seems solid as a rock--the former owner sealed the cracks over and the transom feels solid as a rock.
The motor's a 2001 Mercury 75 hp and it planes the boat at around 3400 rpm's. I'm not using the self-bailing scuppers at the moment, since I live just two miles from the dock and go down to visit the boat every evening.  It has the ping-pong ball type, don't know whether I should expect them to work or not, since I understand motors have gotten heavier than when the boat was made.
Anyway, thanks to all for advice last fall and this spring.  I'm getting a ton of pleasure out of the boat, especially since all of my buddies own bigger rigs and are actually cutting back trips because of gas prices.  Now if I could just get better at fishing . . . :D
Best,
Jeff
1979 170 w/01 75hp Merc
August 01, 2008, 06:14:13 PM
Marcq
« Reply #1 on: August 01, 2008, 06:14:13 PM »
Hi Jeff, long time no see, glad you like your ride, btw the ping-pong ball scupper are self bailing scupper , I love mine, installed them this spring and they do the job not letting water back in the boat but my scuppers are still under water even though I took some weight off the transom going from 85hp to 70hp and removing the tabs, but feel the boat is handling a lot better now for some reason
I haven't had luck with fishing either, but as long as the boat is running good, I'm a happy camper :)
Marc..
