Author Topic: Inspection ports?? Where do I find them?  (Read 1604 times)
April 29, 2008, 10:57:03 AM
Read 1604 times
Fishhyren11
« on: April 29, 2008, 10:57:03 AM »
I have a few of the little screw down and push down inspection hole covers that are starting to age.
Where do I find replacement ports?
Also, on my 170, I have a mistery hole on the front right inside the boat (around the area where the gas fill is)- anyone know what this one is for?
Thanks for your help!
April 29, 2008, 11:10:12 AM
« Reply #1 on: April 29, 2008, 11:10:12 AM »
Boaters World, West Marine, any marine supply.
As for the mystery hole, maybe a picture would help.
April 29, 2008, 11:33:11 AM
Undertow2
« Reply #2 on: April 29, 2008, 11:33:11 AM »
Yes, we carry the Beckson line @ Boater's World.
April 29, 2008, 12:34:44 PM
Re: Inspection ports?? Where do I find them?
« Reply #3 on: April 29, 2008, 12:34:44 PM »
Quote from: "Fishhyren11"
Since your post is about inspection ports, I assume this is the "hole"you are talking about. On my CCP the "hole" in that area is for access to the fuel filler hose. :?
April 29, 2008, 01:49:46 PM
Fishhyren11
« Reply #4 on: April 29, 2008, 01:49:46 PM »
I can see the filler hose, so I'm guessing that's right, just didn't know if there was any other reason besides that....
I also have one in the front right hatch which seems to give access to a drain plug under the front hatch that goes to the side of the hull?
I wish I knew the features this boat came with so I could restore those-
Was it a powered livewell, etc? or is this just to drain ice or whatever I might put in there?
Thanks!!
April 29, 2008, 02:09:22 PM
« Reply #5 on: April 29, 2008, 02:09:22 PM »
Thanks!!
Fishy,
The 170 experts will soon descend upon you so I'll leave you with this. On my 86 /170 there was a "fishbox/cooler" in the middle foward hatch. IIRC it drained overboard but.... :?
I let the experts (with current memories) fill in the rest.
PS..... Check the resource forum here. It has a wealth of info and pretty pics too. :wink:
April 29, 2008, 06:27:48 PM
Miguel
  • Panama
« Reply #6 on: April 29, 2008, 06:27:48 PM »
Mistery hole:  Acces to fuel fill and vent hose.
Hole in front right hatch:  I have the same, but my hand can only reach a couple of inches inside before striking a bunch of foam (probably insulation for the center hatch which is a fishbox with a drain).  This center fishbox is not really too good in maintaining ice, as the hatch istelf is not insulated.
Miguel
[/url]
August 18, 2008, 06:01:33 PM
compcrasher86
Mystery Holes
« Reply #7 on: August 18, 2008, 06:01:33 PM »
Logically, the holes were put there so that if you ever needed to replace an aging or broken fuel fill hose/drain hose or tighten a loose cable clamp, your job wouldnt be mission impossible. Its always a smart idea to have ready access to any kind of thru-hull fitting or hole in the hull if god forbid they ever came loose or sprung a leak, you would be able to patch them easier
Stock 1973 222 Open Fisherman
"Floor it"
