Author Topic: No power in reverse  (Read 700 times)
May 24, 2008, 06:04:30 PM
Read 700 times
14cwater
No power in reverse
« on: May 24, 2008, 06:04:30 PM »
I purchased a 1969 Flatback and have started to do a few cosmetic changes.  I still want to use the boat atleast through tarpon season.  One thing I would like to fix is the motor has very little thrust in reverse.  What could be the cause?  Could it be the wrong length cable?
May 27, 2008, 10:30:25 AM
gcapehart
Has anyone changed the waterpump?
« Reply #1 on: May 27, 2008, 10:30:25 AM »
I have been through this but only when I changed the waterpump. My Johnson has a control rod to change forward to neutral and then reverse. In the disassembly it is possible to not have the rod length at the required length. Adjustments are made winding the furrel end into the shift lever. Anyway on my Johnson it requires you to back out seven complete turns so the the shift works right. This may not be your problem but I thought it might be worth something.   Gary
Maine25XF. Late to the gate we love our boat. Others are humbled by the Sally-Carol. We treat her like family, only better! If you have any tips, insights, or positions on the health benefits of two-stroke exhaust,  please opine and inform. Gary
May 27, 2008, 10:33:17 AM
14cwater
« Reply #2 on: May 27, 2008, 10:33:17 AM »
Thank You.  I will give it a try.
