Author Topic: Through Hull fitting  (Read 1036 times)
December 01, 2005, 04:09:53 PM
Read 1036 times
skinnywater
    • http://www.toughtackle.com
« on: December 01, 2005, 04:09:53 PM »
I was thinking about adding anothe baitwell to my boat, but this will demand a through hull fitting with a seacock. I will have to place the through hull around the center console area if I muster enough guts to drill through the hull  :shock:
Has anyone placed one there before or anywhere that can give some advice. I want to place the through hull further back to the stern, but the way my 19'6" walk around is setup makes it next to impossible without removing the deck.
The worst day fishing is better than the best day at work!!
December 01, 2005, 10:07:08 PM
OldSchool
« Reply #1 on: December 01, 2005, 10:07:08 PM »
1998 Osprey 175 Evinrude 115
1996 Osprey 200 (sold)
1976 Straight Inboard 22-2 (sold)
December 04, 2005, 07:31:05 PM
« Reply #2 on: December 04, 2005, 07:31:05 PM »
I did basically the same thing.  I glassed in a piece of plyood then bored it out for the thruhull, bedded it in 5200.
My livewell is forward of the console so for the drain I put a thruhull in the side just above the waterline.
I had to cut in a deck plate to get my hands down in there to make the connection from the hose to the thruhull.
