Miscellaneous Aquasport Hull Info
Osprey Models
Engine recommendations for a 22-2 flatback
Topic: Engine recommendations for a 22-2 flatback (Read 749 times)
March 30, 2008, 10:21:31 PM
Read 749 times
waterdoc
March 30, 2008, 10:21:31 PM »
I'm looking at purchasing a 22-2 flatback (hull only) and was curious to know what folks would recommend powering this hull with. It will be put on a porta bracket or Bob's jack plate. I'd be purchasing a brand new engine (had my share of problems with used power and would prefer spending the extra for new power with warranty).
Looking for that nice balance between speed/performance and economy. My biggest concern is the weight difference between the 2 and 4 stroke engines. Any advice would be greatly appreciated.
March 31, 2008, 07:56:50 AM
March 31, 2008, 07:56:50 AM »
Most FBs I have seen are powered with either a 150 or 175. I know Bill Miller put a 200 Opti on his and likes it, but his boat sits a little low in the water too.
Personally I was looking for either a 2.5L Merc Opti (up to 175hp) or a 2.9L Suzu (also to 175hp). The Suzuki is obviously a 4 stroke, but only weighs 50lbs more than the Merc. I had also looked at Etecs - but they wanted some high $$$ for them. Locally I can get service on any of the three.
I happened to find a great deal on a 150 Suzu, so I bought it. So maybe narrow it down to two or three motors and go shopping. Good luck!
March 31, 2008, 02:37:23 PM
waterdoc
March 31, 2008, 02:37:23 PM »
Thanks for the info. Where in Tampa do you boat? I'm on the Hillsborough River south of Hillsborough Ave.
March 31, 2008, 09:01:15 PM
March 31, 2008, 09:01:15 PM »
Right now there is no boating, only rebuilding!
But normally I run all over - Tarpon Springs, Upper Tampa Bay, St Pete Beaches, Gandy...
Please post pics as you procedd!
April 01, 2008, 09:52:03 AM
waterdoc
April 01, 2008, 09:52:03 AM »
I'm looking at buying a boat that is already refurbished. I'd just have to have it rigged with power, guages, steering, etc... I will post pics if the deal goes through.
I've also looked at the weights on all the various engines. Looks like ETEC 150-200hp is the lightest at 427lbs. Mercury ProXS 175 is a close second at 431 lbs. The Suzuki 150-200hp 4 stroke is the lightest 4 stroke at 485 lbs.
I suppose that with a forward mounted gas tank and batteries in the center console that some of the weight of the engine could be offset. I'm going to try to find someone that would be willing to take me for a spin in this type of boat before I open up the wallet to take on this project.
Thanks again for your input.
Osprey Models
