22-2 Rebuilds
222 questions 1986
Topic: 222 questions 1986 (Read 1772 times)
December 12, 2007, 05:37:21 PM
Read 1772 times
riomar
222 questions 1986
December 12, 2007, 05:37:21 PM »
I am going to try and keep my problems to this thread I have gutted my 222 .All stringers look great.Rot in transom .All wood had some rot.I will use Coosa for new transom.What other foam choices are there?I am ordering a gas tank and wondered how big was the original tank? looked to be 50-70 gals? also what was the dead rise?14 ? help.
December 12, 2007, 05:48:24 PM
jdupree
December 12, 2007, 05:48:24 PM »
Is this a CCP or Osprey?
John L. Dupree, III
AQABLA84E999
Member #257
December 12, 2007, 09:16:20 PM
Global Moderator
December 12, 2007, 09:16:20 PM »
This thread is useless without pictures!
December 12, 2007, 09:52:57 PM
December 12, 2007, 09:52:57 PM »
Heh heh - what he said!
:afro:
December 13, 2007, 01:44:26 PM
Ben87
December 13, 2007, 01:44:26 PM »
I have a 1987 222 Osprey. It has a 70 gallon tank and a 12 degree deadrise.
January 28, 2008, 09:06:11 PM
riomar
new question
January 28, 2008, 09:06:11 PM »
1st I am not savy enough to post pics here so go to my web page under fish repots.I will put more up this weekend .
www.fish-riomar.com
I have gutted the boat and tossed the liner.I have removed the inside glass and the plywood on the trasom .Now do I go with the Coosa bluewater or Riencell (sp) or some other product to replace the plywood .My friends in the boat building biz all say go with wood .But they all build 40-60' sportfishers (Hatteras style).I like the high desity foams.Any input?????
January 29, 2008, 09:48:02 AM
Mad Dog
January 29, 2008, 09:48:02 AM »
Welcome aboard
Take a look at this site. Tons of good information on rebuilding, especially the pros & cons of wood & foam. I am going entirely with marine plywood for my rebuild. Proper construction and will ensure you have a permanent solution without the added expense of foams.
http://forums.bateau2.com/viewforum.php?f=10
Also, check out this link on this message board.
http://classicaquasport.com/forum/viewtopic.php?t=1194
As far as posting pics, if I can do anyone can. Open a free account at
www.photobucket.com
and upload the photos you want posted there. Photobucket gives you a very simple way to copy a link to this site. Posting pictures with your questions and comments is the best way for us to respond intelligently.
http://s175.photobucket.com/albums/w150 ... Aquasport/
January 29, 2008, 06:44:59 PM
January 29, 2008, 06:44:59 PM »
Come on guys - it's not hard to
post
pictures here. Follow that link and you'll find that it's a piece of cake. Riomar, if you can upload then to your website then you could do it here too just as easy. In fact, you can even point to them on your site from here and they'll show up here, using these instructions. You can handle it.
February 18, 2008, 03:31:12 AM
ddd222
Guest
February 18, 2008, 03:31:12 AM »
hey rio, a few different materials will give excellent results. But don't rush. Besides this site maybe visit classicmako.com, and the ship-shape boating site. John G redid a 70's sea bird soup to nuts including transom w/ a nice armstrong bracket!
But for pete's sake take the oppurtunity to improve access and redesign hatches to service bilge, wiring, livewell plumbing, etc. AND last but not least think carefully about scuppers and the self bailing characteristics of the boat. If a newer d.i. 2 stoke is being mounted(assuming an example of 150 hp), it will be between 50-100lbs heavier than the carbed equivalent the boat the boat was designed for. A new 4 stroke could be as much as 150lbs heavier. Don't quote exactly, i deal mostly w/yamaha and of 200hp and up, but scupper placement and deck drains should be altered slightly. Being too high or low by 1/16 of an inch can be a major drag, GOOD LUCK!
22-2 Rebuilds
222 questions 1986
