Author Topic: Painting below the waterline.  (Read 610 times)
June 15, 2005, 06:42:09 PM
Read 610 times
DEFIANT
« on: June 15, 2005, 06:42:09 PM »
I have been rebulding my transom and I am actually getting to the point where I am planning the painting.
The outside of the transom has been repaired, coated and faired with epoxy resin. I will be painting it with Interlux Perfection since I understand it is not a good idea to gelcoat epoxy.
This paint is not recomended for use under the water line. I will be using antifouling paint under the waterline but do I need to coat the epoxy resin with something before I apply the antifouling paint?
June 16, 2005, 06:57:19 AM
Seadog
« Reply #1 on: June 16, 2005, 06:57:19 AM »
Just painted my console with Interlux Perfection. I like it a lot but I haven't used any other marine paints before, so I don't have anything to compare it too.
I'm faced with the same question as you - what to use for bottom paint.  Don't know for sure but I suspect the bottom paint will have a primer coat that will seal up the epoxy.
1970 Aquasport 222
Spring Hill, Fl.
June 17, 2005, 03:21:49 PM
DEFIANT
« Reply #2 on: June 17, 2005, 03:21:49 PM »
After some research I think I will use Interlux Epoxy Barrier-Kote. (INT 404414).
This paint should seal all water out of the new epoxy and glass. Then I'll cover it with antifouling paint.
