22-2 Rebuilds
Stringer refill
Topic: Stringer refill (Read 1722 times)
August 10, 2005, 11:15:47 AM
Read 1722 times
Capt. Rick
Stringer refill
August 10, 2005, 11:15:47 AM »
Just started a rebuild on 22-2 and turned to the internet for info and found Classic Aquasports. Really nice to know their is a group willing to give advise and help. My question concerns the stringers. I opened the tops and cleaned them out after finding wet foam in them, just not sure what to go back in with. If someone could help advise please. Capt. Rick
August 10, 2005, 12:02:48 PM
DEFIANT
Guest
August 10, 2005, 12:02:48 PM »
Capt Rick,
Welcome aboard!
I used Evercoat Foam-it Flotation. It is a two part high density foam kit. The stuff is not cheap!
Beware when mixing it since it takes about 20 seconds of mixing and it starts to foam like a volcano! The foam it produces is very sticky until it hardens and dries.
Start with small batches until you get the feel for it. If you put too much into a small enclosed area, Watch out!!!
Good luck!
August 10, 2005, 07:40:12 PM
Capt. Rick
stringer fill
August 10, 2005, 07:40:12 PM »
Thanks for your reply. I plan on using it if I don't come up with anything better.
August 11, 2005, 05:37:22 PM
Wilson
August 11, 2005, 05:37:22 PM »
I know some people leave them empty. Can't get wet that way, and the foam provides little floatation or structure.
Wilson Ayala
Tampa, FL
November 06, 2007, 09:30:48 PM
fabuck71
November 06, 2007, 09:30:48 PM »
I did the similar thing and am wondering how to level the tops of the stringers now the new foam is in. Thank you
Alex Buck
Bass Underwriters of Florida
800.528.5386
November 07, 2007, 05:27:42 PM
Mechanical Master
Caps
November 07, 2007, 05:27:42 PM »
You might look at how Shine did his - you probably want to use glass instead of carbon fiber, but the idea is the same:
http://www.classicaquasport.com/forum/v ... c&start=75
Hope this helps!
November 07, 2007, 07:11:20 PM
fabuck71
November 07, 2007, 07:11:20 PM »
Thank you Gone, I figured it out. Look at the progress on the rebuilt page.
Alex Buck
800.528.5386
22-2 Rebuilds
Stringer refill
