Author Topic: Stainless fittings, valve, fuel tank install, 170  (Read 984 times)
August 24, 2007, 11:50:21 AM
Read 984 times
MichaelO
« on: August 24, 2007, 11:50:21 AM »
OK, given, I'm often guilty of quality overkill, but, that doesn't mean I want to change my habits.
For my fuel tank install, I need a 316 3/8" stainless barb to 1/4"NPT to mate with the aluminum fuel outlet fitting.  I do not want to use bronze or brass in contact with aluminum.
I also need a fuel shutoff valve.  My dream valve would look like this:
http://www.defender.com/product.jsp?pat ... &id=141937
as far as having mounting feet.  If would have 1/4"NPT or 3/8" barb ports, and be 316 stainless.  I'd prefer not to use bronze, as those valves always seem to have brass and steel as well.  I've reached down to shutoff a typical bronze valve before, only to discover the steel shaft has frozen.
And I have never felt that brass belonged anywhere on a saltwater boat, particularly on something well out of view and touched only every few years or in an emergency.
Anyone have any sources, or other approaches?
Thanks,
Michael O'
'75 170
Pine Creek
Western L.I. Sound
Cheers,
Michael O'
Odonnell Marine LLC
Fairfield, CT
1975 170
1985 Wellcraft V20
August 24, 2007, 12:58:02 PM
beast819
« Reply #1 on: August 24, 2007, 12:58:02 PM »
heres the pic. Thought I would help your cause in the only way I know how. :D
August 24, 2007, 01:37:16 PM
MichaelO
« Reply #2 on: August 24, 2007, 01:37:16 PM »
What I am looking for may not exist, and in the interest of expediency, I might just use what is there for now.  I'm wondering though, how was the fuel outlet originally routed?  Is mine original?
Here is the top of the fuel tank cover showing the block of wood and shutoff valve:
You can see the hose is routed through the fuel tank cover and siliconed in place; here is the bottom of the cover:
How are other 170s done?
And here are a couple of shots of the boat after initial cleanup (I apologize for poor image quality, I'm using my phone until I resolve my camera issues):
Thanks,
Michael O'
'75 170
Pine Creek
Western L. I. Sound
Cheers,
Michael O'
Odonnell Marine LLC
Fairfield, CT
1975 170
1985 Wellcraft V20
