Author Topic: It's all about the temperature!  (Read 292 times)
April 15, 2022, 11:02:22 AM
Read 292 times
Larryowen
« on: April 15, 2022, 11:02:22 AM »
New 350 Chevy engine with about 400 HP. Running terrific but water temps seem to be too hot. Gauge reading 190º at, say, 3500 rpms. However with my hand-held LED thermometer I get readings of 125º-145º taken from the thermostat housing, the hoses, the manifold, the engine block and the risers. The new crank-driven water pump is flowing a LOT of water. Also has new circulating pump system. Can a new gauge and sender be that far off ... what am I missing?
April 15, 2022, 11:29:51 AM
dbiscayne
Re: It's all about the temperature!
« Reply #1 on: April 15, 2022, 11:29:51 AM »
or is the handheld LED that far off?
April 15, 2022, 01:47:03 PM
Larryowen
« Reply #2 on: April 15, 2022, 01:47:03 PM »
Good question. I did use  2 different hand held units with very close to the same readings.
