Hey Guys,
Unfortunately I'm looking to sell my 1976 17'0" Osprey. Im located in Tampa Bay and open to answering any/all questions at 404-625- 510seven. I'll work on adding pictures to the add or could easily send via text. Also, here is the ad on Craigslist [https://tampa.craigslist.org/pnl/boa/d/largo-1976-aquasport-170-osprey/7350353664.html]
The boat was completely restored by the previous owner, included everything: fuel tank, center console, electrical wiring, plumbing, pumps, gauges, stereo, marine radio, custom lean-post live-well, Yamaha 115, swim ladder, Birdsail rod-holders, bimini top, etc.
I did additional work in May of 2020.
• All the hatches re-cored and fiberglassed;
• The rigging tray from the console to transom (original design) was removed and a 2” rigging tube installed
• Entire starboard side of the boat re-cored and fiberglassed
• The entire deck was sprayed with Alwgrip non-skid
• 9x12 electronic Lenco trim tabs installed
• New fuel lines and throttle cables
• New PowerTech SDC3 17 prop
The original owner stored the boat in an air conditioned detached garage. I currently store it completely covered in my garage. The boat is flushed, washed, and dried (hull, boat, and bulkheads) after each use. Also, only non-ethanol fuel has ever been used. Boat is in great condition and everything works perfectly.
Asking $17,500; make an offer. In no rush to sell and will continue to use the boat.
Motor:
• 2003 Yamaha 115 four stroke
o 390 hours
o Professionally maintained annually
• Minnkota 60” shaft 80# Terrova trolling motor (new in October 2017)
o Quick release bracket
o Spot lock/anchor, autopilot, tracking, etc. capability
Trailer:
• Tandem axle Performance Trailer – overkill for a 17’ boat, but great piece of mind.
o New wiring and lights installed in May 2020
o Hubs, springs, bunk supports, bunks replaced November 2019
Boat:
• 35 gallon custom lean-post live-well
• 27 gallon fuel tank
• 4 batteries installed in battery trays under the center console
o 2 deep cycle for trolling motor (new in Nov 2019)
o 1 cranking and 1 house (new in May 2018)
o 2 dual bank onboard chargers; 1 for TM batteries and 1 for cranking/accessory batteries
• 1 float bilge pump installed in bulkhead
• 1 manual bilge pump installed inside transom
• Stainless steel steering wheel with knob.
• Custom Bimini top and sun pad for casting platform (not included in pictures)
Electronics:
• Simrad GO7 XSE with TotalScan transducer (new in May 2018)
• Marine Head unit
• 2 6.5” Fusion Speakers
• Marine Radio
Mark
