Author Topic: 1982 22.2 ccp total rewiring - any and all advice welcome  (Read 3879 times)
December 18, 2006, 06:48:28 AM
Re: LEDs
« Reply #15 on: December 18, 2006, 06:48:28 AM »
Quote from: "GoneFission"
You need to get an LED bulb that matches up with what you are trying to do - a lot of these bulbs are made for automotive backup or turn signals.  That won't work for marine use - you need a 1004 type bulb.  Look for an bulb with 360 degree LED coverage.
To replace a Perko anchor light, you need what these people call a 1142 - a dual contact bulb with level studs (unless it's a generic pic).
Here is the source website.
Or you can do like I did and make up your own for a couple bucks.  I will try to assemble one this week and post the instructions and pics on this website.  If you know which end of a soldering iron is hot, you can probably do it!!  No need to spend $100+ for LEDs for your boat. :wink:
Another reason to have this "Resource" section  :wink:
