Aquasport Discussion
Boat Brass Drain Tube
Topic: Boat Brass Drain Tube (Read 488 times)
July 29, 2019, 07:55:19 PM
Read 488 times
mtgtool
July 29, 2019, 07:55:19 PM »
I'm having a hard time finding 1-3/4" Brass Drain Tube for the floor drains. Can any one help me on this? I'd like to say thanks for all the help giving on project.
July 30, 2019, 07:50:42 AM
Global Moderator
Re: Boat Brass Drain Tube
July 30, 2019, 07:50:42 AM »
Why 1-3/4" ?
July 30, 2019, 08:57:55 AM
outboardsurplus
July 30, 2019, 08:57:55 AM »
I think they are 1 1/4 and just bought a 2 pack off ebay
July 30, 2019, 09:01:27 AM
mtgtool
July 30, 2019, 09:01:27 AM »
That is the size of brass tub in there now.
July 30, 2019, 01:25:04 PM
Global Moderator
July 30, 2019, 01:25:04 PM »
And it's located where?
Photo perhaps?
July 30, 2019, 08:29:31 PM
mtgtool
July 30, 2019, 08:29:31 PM »
I took a picture so you could see what I was talking about. They are an 1 3/4" holes. I cannot find the tubes already made up for the job. I did find an 1 3/4 OD by 12" tubing and guess I'll have to make my own. For the life of me I cannot figure out how to post the pictures (even with the instructions). They are in My Photos. Thank you Captain Bob and all of you
Here ya go.
July 31, 2019, 07:39:52 AM
July 31, 2019, 07:39:52 AM »
Since you’re redoing your transom, you can make the holes whatever size you want. Later Aquasport used 1” tubes.
Here’s a thought, don’t use brass tubes. They all eventually develop stress cracks and allow water into the transom core. You can simply epoxy PVC tubes through your transom. The gray PVC sold for conduit is more UV resistant.
July 31, 2019, 09:13:46 AM
mtgtool
July 31, 2019, 09:13:46 AM »
I like the PVC pipe idea. That is easy to work with. I believe that is the way I'll go. Thank you
July 31, 2019, 12:25:06 PM
July 31, 2019, 12:25:06 PM »
As long as your scuppers are above the waterline and you can find a way to plug the scupper in an emergency, you can go with whatever size scuppers you want.
