Author Topic: bilge thru hull  (Read 482 times)
May 18, 2017, 01:46:42 PM
Read 482 times
DanaDave
bilge thru hull
« on: May 18, 2017, 01:46:42 PM »
Is there no other way to access the bilge thru hull on a 1988 Striper other  than drilling and installing a deck plate?
thanks all
DD
May 18, 2017, 03:22:28 PM
Re: bilge thru hull
« Reply #1 on: May 18, 2017, 03:22:28 PM »
Yeah, unfortunately for future owners, parts are often installed before assembly of hull and liner.  It's much worse on newer boats.
May 18, 2017, 03:39:16 PM
Re: bilge thru hull
« Reply #2 on: May 18, 2017, 03:39:16 PM »
Do you have a 170/175 or 200 Striper?  BTW your boat is an Osprey model with a Striper fishing option package.
And as mentioned some things on a boat are installed before the deck is placed on the boat.
May 25, 2017, 02:20:00 PM
DanaDave
Re: bilge thru hull
« Reply #3 on: May 25, 2017, 02:20:00 PM »
Thanks for the info - that's what i thought as well. It is a 200 striper (yep - Osprey with fishing package) I think a 6" deck plate will give me enough room, 4" I don't think will allow enough room to work.
thanks again
DD
