Author Topic: 29ft Aquasport Tournament master sportfisherman  (Read 3736 times)
July 13, 2012, 04:17:14 PM
Read 3736 times
kennv
« on: July 13, 2012, 04:17:14 PM »
I recently purchased a 29ft Aquasport tournament master, but i can't seem to find any specs on the boat. I would like to know what the person capacity is and what size and pitch the props are supposed to be. I can't seem to get the rpms over 3500. If anyone has any idea where i can find out this information please let me know.....
July 13, 2012, 04:35:29 PM
Re: 29ft Aquasport Tournament master sportfisherman
« Reply #1 on: July 13, 2012, 04:35:29 PM »
July 13, 2012, 05:31:56 PM
kennv
« Reply #2 on: July 13, 2012, 05:31:56 PM »
Thank you that helped, but i still need a little more information if anyone else has any please post it.
July 13, 2012, 09:11:27 PM
manifishdestiny
« Reply #3 on: July 13, 2012, 09:11:27 PM »
Quote from: "kennv"
I recently purchased the same model boat and was having the same problem. I just changed the oil and filters as well as the fuel filters and it seemed to have made a big difference in the performance. Just a thought. Let me know what you come up with.
July 16, 2014, 08:08:50 AM
joey4240
  • NorthEast
« Reply #4 on: July 16, 2014, 08:08:50 AM »
17x17 for the Volvo penta small block. wot should be 4600rpms. I think 12 is max persons. there is a brochure with specs somewhere on this site.
July 16, 2014, 09:36:00 AM
« Reply #5 on: July 16, 2014, 09:36:00 AM »
Quote from: kennv
1. http://classicaquasport.com/smf/index.php?topic=11771.msg117355#msg117355
2. http://classicaquasport.com/smf/index.php?topic=9795.msg88058#msg88058
3.http://www.classicaquasport.com/gallery ... hp?cat=553
4. http://classicaquasport.com/smf/index.php?topic=4891.0
There's a forum here dedicated to these larger Aquas. Your original post resides here now.
August 13, 2014, 08:09:28 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #6 on: August 13, 2014, 08:09:28 PM »
19x19 4-blades with some cup was where the magic started to happen for me with carb'd Vortec 350's.  Was slightly over-propped, but pretty close.
Ryan
August 19, 2014, 05:10:11 PM
Fishing Fool
    • http://www.keyslobster.com/
« Reply #7 on: August 19, 2014, 05:10:11 PM »
I have a 1988 290 TM with 350 Crusaders that are 260 HP.
My props that came with the boat are 19 x 21   3-blades
I run the engines at about 2900 RPM for cruising, top end is about 4,200 RPM on mine
Jeff
August 19, 2014, 05:17:08 PM
« Reply #8 on: August 19, 2014, 05:17:08 PM »
Thanks Joey, Salt and FF but the original poster hasn't been back in over 2 years.
Still, this is valuable info on these big girls. :salut:
 :thumright: :thumright:  :thumright:
August 19, 2014, 06:23:03 PM
« Reply #9 on: August 19, 2014, 06:23:03 PM »
That shows what kind of people we are - we don't care if the member is active, inactive, dead, asking from another dimension - we help them all  :cheers:  :cheers:  :salut:
May 14, 2016, 08:12:22 PM
beaker
« Reply #10 on: May 14, 2016, 08:12:22 PM »
Brand new to the site. 18x18 seem to work fine on my 29...
March 28, 2017, 12:10:59 PM
dannyturbine
« Reply #11 on: March 28, 2017, 12:10:59 PM »
The 1987 290 I just purchased has 350's @ 260-270 horse and is pushing 3400-3500 at wide open throttle. The previous owner stated that both engines were just re built and have less than 20 hours on them. He purchased it right after the engines were rebuilt and he isn't sure if the 18 inch props are original. I have requested the pitch and the gearbox ratio as well as shaft bore. I'm currently on a project in Saudi Arabia and as the boat is sitting on the hard in Wildwood, NJ. I would like to have the props changed before she is put in. Can anyone tell me what WOT should be for this boat and proper or best prop set up? I'm thinking 17 x 16 would be an improvement......any thoughts???
April 08, 2017, 12:56:33 AM
George290
« Reply #12 on: April 08, 2017, 12:56:33 AM »
I have a 1988 290 with the 350's @260 hp original with 1400 hours and wind up to 4400 WOT with 19 x 19 3 blade props.  The average for this boat is 4200-4600 depending on props, load, bottom condition, etc.
