Author Topic: TPS Test Harness for 1999 200 Yamaha OX66  (Read 1379 times)
September 11, 2015, 12:33:21 PM
Read 1379 times
jdupree
« on: September 11, 2015, 12:33:21 PM »
I need to test my TPS (Throttle Positioning Sensor) on my motor. Naturally, you need a test harness from Yamaha. The harness is $35.00! Does anyone have one or know where I can get one any cheaper? I know how to test the TPS but I have to have the harness. Thanks in advance!
John L. Dupree, III
AQABLA84E999
Member #257
September 11, 2015, 08:41:45 PM
Re: TPS Test Harness for 1999 200 Yamaha OX66
« Reply #1 on: September 11, 2015, 08:41:45 PM »
John,
Would you know a TPS harness if you saw one?  I did a lot of troubleshooting on my OX66 a few years ago.  In some cases I just made jumpers that I could connect a DVM to, and in other cases, if I could find the proper harness cheap, I purchased it.  The harness in the pic below does not have any distinguishing markings on it, and I forget what it was specifically for, but if the connectors look like they are a match for your engine, you are welcome to borrow it.  I'll also look around the garage a bit, as I may have another test harness hiding somewhere.
September 11, 2015, 09:00:25 PM
« Reply #2 on: September 11, 2015, 09:00:25 PM »
Hold the phone!  I think I found it!  I have a 06857 test harness, which a quick search of the web reveals is a TPS test harness.  You will need to verify it is the correct harness for your engine (mine is a 2002 OX66 200 hp).  I don't want to sell it, but if you want to borrow it, let me know.  I think the harness above is for testing the O2 sensor.  I can lend both of them to you if you want.  Here is a pic of my TPS harness:
September 11, 2015, 10:34:19 PM
jdupree
« Reply #3 on: September 11, 2015, 10:34:19 PM »
That is the exact one Craig!!!!!  I know you don't want to sell it and that is fine.  I think my TPS is out of adjustment or going bad.  I will pay the shipping both ways if I could borrow it?  I really appreciate you taking the time to help me out :c017:  Just let me know.
John L. Dupree, III
AQABLA84E999
Member #257
September 11, 2015, 11:37:02 PM
« Reply #4 on: September 11, 2015, 11:37:02 PM »
No problem, John!  Just PM me your address and I'll get it right up to you.  You have the October gathering coming up, right?  Hopefully you get the boat running good by then!
