Author Topic: 2004 Aquasport 19 Osprey CC  (Read 334 times)
April 21, 2015, 07:45:00 PM
Read 334 times
ashefrin
« on: April 21, 2015, 07:45:00 PM »
I just purchased a 2005 Aqua Sport 19 Osprey CC and it has a 50 gal internal gas tank. The boat has been sitting for over a year and I am trying to figure out the best way to get the old gas out of the tank.  Any help would be appreciated... Andy
April 22, 2015, 03:53:31 PM
williecoyote
Re: 2004 Aquasport 19 Osprey CC
« Reply #1 on: April 22, 2015, 03:53:31 PM »
Shove a length of garden hose down into your fuel tank. Put the other end of this hose into a container to catch the fuel in. Basically a siphon hose.
Get an air hose from a compressor, and blow compressed air into the fuel filler. You will have to keep a rag around the air line at the fuel filler in order to pressurize the fuel tank. The pressure inside the tank will force the fuel out the siphon hose.
If there are any vents from the fuel tank, you would have to temporarily plug them for this to work.
April 22, 2015, 04:12:16 PM
« Reply #2 on: April 22, 2015, 04:12:16 PM »
Same principle as Willie's suggestion, but disconnect the fuel line from the engine and put the end in a container.  The end of the fuel line must be lower than the bottom of your tank, so you may need to add a few feet.  The lower the free end, the better the flow will be.  Squeeze the primer ball until you get flow started.  Then let the siphon do the work.  Make sure you have enough containers to collect all the contents.  This won't get 100% of the contents, but it should get you down to the pickup intake.
April 22, 2015, 04:27:43 PM
« Reply #3 on: April 22, 2015, 04:27:43 PM »
Both methods above work.
I use the second (I have a dedicated fuel pick up) when I do my yearly drain.
April 23, 2015, 11:13:45 AM
ashefrin
« Reply #4 on: April 23, 2015, 11:13:45 AM »
Thanks for all the advice guys I will give it a try....Andy
April 24, 2015, 08:58:15 AM
ashefrin
« Reply #5 on: April 24, 2015, 08:58:15 AM »
Thanks again  I was able to disconnect the fuel line at the primer bulb and put a fuel line into that  then I was able to use a compressor and pump air into the tank  once the siphon started I was all set  took about 1.5 hours but I got 15 gallons out....thanks ...Andy
