When'd You Last See One Of These?
Topic: When'd You Last See One Of These? (Read 2661 times)
February 06, 2005, 07:58:53 AM
Read 2661 times
Seadog
February 06, 2005, 07:58:53 AM »
This is a console from a 1970 AS 222. Above the wheel is a frozen up compass, to the right of the compass is an EIGHT TRACK STEREO, along with two speakers set on top of the console. You can't see it in this picture but under the console is a VHF radio thats half the size of a microwave oven and weighs twice as much. Both probably state of the art in the early 1970's.
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 08:01:34 AM
Radioshop
February 06, 2005, 08:01:34 AM »
I bet those speaker magnets didn't do the compass any good. Someone probably didn't think that one through too well. Mine is mounted in an aluminum riser. Everyone sees it and thinks it'll mess with the compass until I tell them it's aluminum.
Miamuh, Florida
February 06, 2005, 08:01:53 AM
Wilson
February 06, 2005, 08:01:53 AM »
Good God!!
Those throttles are unbelievable!! Was that for the twin 70's?
Is that a pic of your console before you tore her apart?
Wilson Ayala
Tampa, FL
February 06, 2005, 08:15:01 AM
Seadog
February 06, 2005, 08:15:01 AM »
That's probably a good guess Wilson - twin 70's. The boat came with out power so I don't know for sure, but I know that was a popular configuration back then. In the pic the guy just cut out a rectangular hole in the console to run the throttle cables. Under the control box was a piece of teak he tried to form to the console top to make the box lay flat. He did a decent job of it, it just looked like hell. The gas tanks where twin steel and sat under the console on top of the floor. You can see the gas caps on both sides of the console top at the rim of the wheel. Yea - this was the console before I ripped it apart.
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 08:27:17 AM
Seadog
February 06, 2005, 08:27:17 AM »
In the second pix you can almost see the radio under the console.
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 08:32:55 AM
Seadog
February 06, 2005, 08:32:55 AM »
Don't know why the size of that first pic got wacked out. I'm using photobucket and I'll try to resize before posting in the future.
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 08:52:25 AM
Wilson
February 06, 2005, 08:52:25 AM »
Believe it or not, once I got everything off my console it was 3 times as bad as that. I've never seen so many holes.
Wilson Ayala
Tampa, FL
February 06, 2005, 09:31:49 AM
Anonymous
Guest
February 06, 2005, 09:31:49 AM »
Wilson - Did your console have one of these holes?
I'm redesigning the whole thing - raising the top about 6 inches and reconfiguring the layout. It'll be awhile but it's coming along - slowly.
February 06, 2005, 09:38:01 AM
Seadog
February 06, 2005, 09:38:01 AM »
Whoops - somehow I logged in as a guest. I need some more coffee so I will wake up and pay closer attention!!
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 09:40:29 AM
Seadog
Reply #9 on:
February 06, 2005, 09:40:29 AM »
1970 Aquasport 222
Spring Hill, Fl.
February 06, 2005, 02:55:49 PM
Radioshop
Reply #10 on:
February 06, 2005, 02:55:49 PM »
I think when they went to the newer hull (the one with some deadrise) the console got an overhaul too. Seadog, I'll bet that old VHF had some tubes in it. I still have the Pierce-Simpson Bimini that was OE on my boat. A whopping six channels with rocks (crystals) for each channel. I'm planning to go for the ultra clean look on when I do the re-furb. I want to clean up to two guages tach, voltmeter and, water pressue. I may even eliminate the switch plate, which yours doesn't seem to have. I got to thinking about all the electrical functions on that pannel and most of them were lights, which could mostly be accomplished with a two position pull out switch. First position anchor light, second running lights. I'd have to do something for courtesy lights. If I eliminated the switch plate, I'd want to flush mount the GPS/Plotter/Fishfinder into the dash itself.
Miamuh, Florida
February 06, 2005, 07:05:22 PM
Seadog
Reply #11 on:
February 06, 2005, 07:05:22 PM »
Radioshop - Pierce-Simpson Bimini? Switch Plate? Rocks? Crystals? WTF is that? You lost me. Flush mount, running lights and GPS combo I got. HA! I see from your profile your a radio guy so you'll be a good guy to know and have around when we need some electrical advise. I take it your rebuilding your console too? Got any pix?
1970 Aquasport 222
Spring Hill, Fl.
July 20, 2006, 09:03:54 PM
carr
big bucks
Reply #12 on:
July 20, 2006, 09:03:54 PM »
if you have the key for the controll boxes there is a guy who lives for EVUNRUDE ELECTRIC SHIFT PARTS. 888-987-7937 ask for BOB
