Aquasport Discussion
Dry weight 245 Tournament
Topic: Dry weight 245 Tournament (Read 281 times)
July 09, 2013, 09:32:52 AM
Read 281 times
Hozenya
July 09, 2013, 09:32:52 AM »
Looking to see if anyone knows the dry weight for a 1998 245 Tournament CC with twin 150's? Looking to get some jack or lift stands to lift the boat off the trailer for painting.
Thanks in advance.
1998 245 Tournament Master
Twin Johnson OceanRunner 150\'s
July 09, 2013, 10:48:19 AM
Global Moderator
Re: Dry weight 245 Tournament
July 09, 2013, 10:48:19 AM »
Here's a start.
http://www.classicaquasport.com/gallery ... 07&cat=633
It's with a single 200hp but you could back into the weight with a few gazintas.
Hard to read (for old eyes) but it appears to be about 4100# - 455# for the 200 + 800# (for the 2 ea. 150s) so...
4445# +/-. Knowing the correct model of 150 you have (obviously I don't) you could narrow it down a bit but jacks rated above 5000# would give you a little ( :| ) room for safety. Above that (
) and you should feel comfortable.
Here's yet a little more reading on the stands themselves. Not cheap but good info/ideas
http://www.boatstands.com/node/166
