Author Topic: Gas Tank  (Read 1021 times)
June 15, 2006, 09:57:29 AM
Read 1021 times
Straight A's
Gas Tank
« on: June 15, 2006, 09:57:29 AM »
Does anyone know the height of the gas tank in a 1986 Osprey 17' cc?  I am in town today close to a WM and need to buy a new sending unit but forgot to measure the height before I left.  I believe the unit for up to 12" looks right but just want to make sure.
Thanks,
Kent
Northern Neck
Virginia
June 15, 2006, 11:03:09 AM
jdupree
« Reply #1 on: June 15, 2006, 11:03:09 AM »
Kent,
Just replaced the tank in my 1988 170.  The height of my tank is 6".  I have the rest of the measurements if you need them.
John L. Dupree, III
AQABLA84E999
Member #257
June 15, 2006, 04:31:25 PM
Straight A's
« Reply #2 on: June 15, 2006, 04:31:25 PM »
Thanks!  I will grab a sending unit on the way home.
Northern Neck
Virginia
June 15, 2006, 04:50:04 PM
osprey170
« Reply #3 on: June 15, 2006, 04:50:04 PM »
Yup 6" - Mine is an '85 with the same tank dimensions as jdupree
1985 Osprey 170
June 16, 2006, 10:21:51 AM
DEFIANT
« Reply #4 on: June 16, 2006, 10:21:51 AM »
I replaced the sending unit in my 222 CCP last fall. The unit was made by Tempo and it could be cut to fit most any tank and give accurate readings.
