Author Topic: Aquasport 19-1 Osprey or Gull?  (Read 623 times)
June 06, 2014, 12:29:07 PM
Read 623 times
christragakes
« on: June 06, 2014, 12:29:07 PM »
I have an Aquasport 19-1, I do not know weather it is a Gull or Osprey! Also was it suppose to have an inboard fuel tank? And is the deck suppose to be autobailing??
June 06, 2014, 12:32:34 PM
christragakes
Re: Aquasport 19-1 Osprey or Gull?
« Reply #1 on: June 06, 2014, 12:32:34 PM »
I am going to add pictures, but I can not figure out how to add them, it tells me the pixels are to large.
June 06, 2014, 12:56:39 PM
« Reply #2 on: June 06, 2014, 12:56:39 PM »
I believe on the 19-1 the fuel tank is inside the console.  I don't think the Osprey model name was around yet.  All Aquasports came with self bailing decks.
June 06, 2014, 01:22:06 PM
« Reply #3 on: June 06, 2014, 01:22:06 PM »
Quote from: christragakes
Found schoolin' in the upper water column of most forums.
http://classicaquasport.com/smf/index.php?topic=12725.0
June 06, 2014, 01:32:59 PM
christragakes
« Reply #4 on: June 06, 2014, 01:32:59 PM »
What would be some causes for not allowing the deck to be auto bailing?
June 06, 2014, 01:37:45 PM
« Reply #5 on: June 06, 2014, 01:37:45 PM »
Blocked scupper drains or... as these boats age they gain weight and sit lower in the water.  so the scupper drains are no longer above the waterline.
June 06, 2014, 06:11:18 PM
« Reply #6 on: June 06, 2014, 06:11:18 PM »
Also a big culprit (possibly the main culprit) is putting a new(er) motor on it that weighs more than the original design of a 75hp.  Some of the newer motors weigh upwards of 100+ more pounds than the older motors that the boat was designed for.
Read the link that CB posted on how to post pics - it's very easy.  If you are uploading them to your gallery on this site, the site will size them down automatically so they can't be too big.  If you are posting a link from another hosting site (like photo bucket) the pics are limited to 1100Wx800H.
June 06, 2014, 09:39:33 PM
« Reply #7 on: June 06, 2014, 09:39:33 PM »
Couple of good points.
As they age, they'll leak around the bilge (garboard plug) drain. Original sleeve adhesive dries out...they leak. When the boat is in the water, the water fights to get up through the transom plywood to its own level. She becomes heavier through the years as the transom continues to leach and upwardly absorb water.
The water is encapsulated by the fiberglass skins. Engineered to keep water out, they are equally adept at holding water in.
Rick makes an excellent point on engine weight. Tough to find a strong single under  300 pounds nowadays.
One of the reasons clean two-strokes are still desirable and worth good money.
