Hey Aqua,It could be a clogged vent that will not allow the fuel to draw. Try running it with fuel fill cap off or very loose and see if it runs better. If it does, look and see if the fuel vent is clogged with debris,bugs. etc. It can also be a kinked or degraded vent hose in need of replacement. Lastly, the fuel line is plugged between the tank and the engine. Take off the primer bulb and blow through the line and see if thats the problem.
