Gallery
Gallery
Transom plate
Topic: Transom plate (Read 822 times)
December 10, 2012, 02:15:00 PM
Read 822 times
bayman
Transom plate
December 10, 2012, 02:15:00 PM »
Hey guys, i was working on the transom today and noticed that i am having som delam going on. My plans were to bolt a plate in to sandwich it together then just glass the seem up top. I was thinking about useing some plywood that has been enclossed in glass. I know allot of people use ss for plates but i dont have that type of cash right now. Any one have any oppinons on this?
December 10, 2012, 02:16:20 PM
bayman
Re: Transom plate
December 10, 2012, 02:16:20 PM »
I tried adding a pic but it wont allow it
December 10, 2012, 03:47:04 PM
TheKid
Re: Transom plate
December 10, 2012, 03:47:04 PM »
Aluminum.
Before you proceed, consider the cost and labor going this route versus a complete transom rework.
Use the search function. There are a ton of transom posts on here.
December 10, 2012, 04:07:33 PM
Purgatory
Re: Transom plate
December 10, 2012, 04:07:33 PM »
Any scrap metal yard will have stainless plate at a steal. I bought a 4 X 4 sheet for a home project a while back for $16.00. They buy/sell by weight.
December 10, 2012, 04:24:35 PM
bayman
Re: Transom plate
December 10, 2012, 04:24:35 PM »
I checked the transoms core and it all seemed dry so i dont wanna get into it if i dont really have to. What thickness would you guys prefer?
December 10, 2012, 05:08:47 PM
jdupree
Re: Transom plate
December 10, 2012, 05:08:47 PM »
You stated that the transom appears dry
If that is so, sounds like the transom cap is cracking which is pretty common due to age. If the transom is not flexing, I don't see where a plate is needed. Sounds like you just need to seal up the delamination.
John L. Dupree, III
AQABLA84E999
Member #257
December 10, 2012, 05:11:52 PM
Rigging Master
Re: Transom plate
December 10, 2012, 05:11:52 PM »
1/2" aluminum. But what you are saying is to install the plate INSIDE to the transom, correct? Then you big time have to mess with the core. If you are saying a plate on the inside and the outside of the transom, then you are talking your "sandwich"...
A thought. If your transom coring appears dry, why not inject some resin into the voids?
December 10, 2012, 05:12:29 PM
Rigging Master
Re: Transom plate
December 10, 2012, 05:12:29 PM »
JD, I think my second option is what you have in mind...
December 10, 2012, 07:40:12 PM
bayman
Re: Transom plate
December 10, 2012, 07:40:12 PM »
If only i can add a picture it would explain it is right under the cap but runs the whole length of the "cap" how would i glue it back in place epoxy it then clamp it place ? The guy i got it from said he had a ss plate on it then he used 5200 it fill the cap gap so it stayed dry
December 10, 2012, 08:05:02 PM
Rigging Master
Re: Transom plate
Reply #9 on:
December 10, 2012, 08:05:02 PM »
bayman,
Are you familiar with photobucket?
December 10, 2012, 08:14:56 PM
Global Moderator
Re: Transom plate
Reply #10 on:
December 10, 2012, 08:14:56 PM »
Quote from: "bayman"
Try this for your pics.
This assumes you're using a Windows based PC.
Get the photo somewhere on the PC..anywhere, drive type doesn't matter; flash, CD, DVD, hard, floppy..... just so long as you know where it is......
Now open the Forum and click on the Photo Gallery.
Click "Upload Photos" in the upper right side of screen.
Photo Gallery will now recognize you.
Look on the right side of the screen for the word "Browse". There will be several. Choose the top one and click on it.
A drop down box appears and assumes you know where the photo is and you click on the proper location.
Location loads in empty box to the left of "browse". If correct then scroll down and click "Upload/Submit".
Computer does its thing and a new screen appears.
Your photo in thumbnail size appears on left, make sure it's the one you want and that the little box to the right is checked.
Scroll down and click on the "Process" button at the bottom.
Computer does its thing.
You are now in your personal Gallery. Click on the photo and it opens in a new screen.
Now you can either right click on the pic and then click on "save image location" in the drop down box or use the options on the right. Your choice.
If you right clicked and clicked the save image location (old school) you do this...
Now, go back to your post and click on the "IMG" box at the top. That places [img][img] in your post.
It even places the cursor between the two [img]s so you just hit control/v and you're good to go.
If you clicked on either box to the right of your photo, clicking on the IMG is not needed (common error), just hit control/v where you want the photo in your post.
In either instance, Photo Gallery sizes your photo to fit.
December 10, 2012, 08:38:03 PM
bayman
Re: Transom plate
Reply #11 on:
December 10, 2012, 08:38:03 PM »
I am useing a iphone any idea how to upload off of this?
December 10, 2012, 09:04:39 PM
Purgatory
Re: Transom plate
Reply #12 on:
December 10, 2012, 09:04:39 PM »
E-mail it to yourself, pull from the mail.
December 11, 2012, 08:12:42 AM
Global Moderator
Re: Transom plate
Reply #13 on:
December 11, 2012, 08:12:42 AM »
Whoa, listen to the Geek Squad commando. (inside joke)
Scott is right on with that.
I'm not an Apple guy but there are members that post pics from both the iPhone and iPad so it's doable.
I posted from my Galaxy S III so smart phone posting can be done. It's a damn sight easier for old guys from a computer.
Mod Edit:
Using the "Search" function, I found my old post when I learned how to post photos from the phone. This should work basically the same for an iPhone. Hell Samsung first copied then paid for the the iPhone "system".
Since the pic from your phone is in whatever Apple calls their version of a
photo gallery
, it's easy to use the info in my earlier post to get the pic into
this Forum's Photo Gallery.
The technique is identical. Open the Forum gallery and direct it to the iPhone gallery. Once you have the pic in the Forum Gallery, follow the directions below.
Select the pic you desire with a finger touch (duh), then select the "Linked Image" box to the right of the photo by
holding your finger on the box.
This gives a pop up menu allowing you to save the link and touch
"copy all"
(again, this is for my Galaxy, your iPhone may be somewhat different).
Then it's business as usual. To insert a pic into your post,
touch and hold
the dialog box (where you're typing your post) and another menu box appears. Touch
paste
and you're home free. Do not (as I was doing) touch the toolbar boxes above the dialog box (Thank You Fearless Leader
So you can take a pic with your cell phone, load to your phone gallery, access the Forum site online, open your Member Gallery, download from phone to Aqua site and finally add it to a post. All with a smart phone.
If you have not placed any photos in this Forum's Photo Gallery, no big deal. Follow this lead from above.
Open the Forum, then click on the Photo Gallery button on the tool bar at top.
This will create your personal gallery.
The photo below was transferred from my phone, to the Forum Gallery, and placed in this post, all by using the phone.
This was 2.2 Meg pic (I believe) on my phone and the Forum Gallery re-sized it automatically.
Ain't Life grand.
December 11, 2012, 09:57:36 AM
dirtwheelsfl
Re: Transom plate
Reply #14 on:
December 11, 2012, 09:57:36 AM »
Ive got a "snapbucket" app on my iphone. It sends pictures from your phone to your photobucket. Then just go to your photobucket, resize to 640x480 or whatever and copy and paste the img code...
Transom plate
