Question, and this goes to all the rebuild people. On a 170 Striper, is there any space below the deck that you can fish wires for electronics?
I would like to eventually add a trolling motor to my 170. I have a locker up front that is holding my anchor and rode, so nothing there. I was thinking about putting the batteries in the center console but didn't know if I could run the wire up front or not.
If there is space, I thought about cutting the wires for my navigation lights and using them as fish to tie a new set of wires to for both navigation lights and a trolling motor and using the old wires to pull the new ones back to the center console. If there is ample space under the deck to do this I will do it. But I don't want to attempt it and get partway only to have it bind up and then I am SOL with no navigation light wiring.
If you guys this will work, I will pre-wire now and put a plug up front for the trolling motor. Then when I find one I can afford I will buy it and just have to install it and not worry about how to get to power.
Joe
