Author Topic: Steering Wheel removal  (Read 4450 times)
January 27, 2013, 01:25:36 PM
Reply #30
JETPILOTLU
Re: Steering Wheel removal
« Reply #30 on: January 27, 2013, 01:25:36 PM »
Now that I have an idea as to how to remove the wheel, I have a question.
Already checked the hydraulic lines to/from my 200 Evinrude Ocean Pro on my 21.5 Aqua Explorer.  Don't seem to be leaking, bent, etc...
The wheel is just spinning freely, left and right.  What may this be?
Capt. Louie
January 27, 2013, 01:31:30 PM
Reply #31
gman 82 aquasport
« Reply #31 on: January 27, 2013, 01:31:30 PM »
Can you see if the key is still on the shaft, if it has moved or fallen out the wheel would free spin..A second thing to look at would be if the helm is low on fluid, lines might have fluid in them but if the helm is to low it will not turn the engine. Hope this helps :thumright:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 27, 2013, 05:40:20 PM
Reply #32
JETPILOTLU
« Reply #32 on: January 27, 2013, 05:40:20 PM »
Im following everyone's advise and I did get the wheel of my 21.5 Explorer.  By myself.  Lots of WD40, 2by and a hammer.  Now that it is off, what do I do?  It appears to be the power steering reservoir.  It's empty and I hear some clanking sound when I turn the mounting stud.    Where do I go from here?
FYI - the motor won't turn left or right, even manually.
Capt. Louie
January 27, 2013, 06:59:42 PM
Reply #33
« Reply #33 on: January 27, 2013, 06:59:42 PM »
While it's apart, start here.
viewtopic.php?p=90919#p90919
Add this.
viewtopic.php?p=48763#p48763
When finished, do this as per item #4.
viewtopic.php?p=76584#p76584
If the motor won't move, read all items shown on the Teleflex site. You may need to address steering tube problems on the outboard as well.
Resource forum is your friend.
January 27, 2013, 07:00:36 PM
Reply #34
« Reply #34 on: January 27, 2013, 07:00:36 PM »
Quote from: "JETPILOTLU"
Capt. Louie
Louie, that sounds like a bad check valve inside the helm pump.  Here's an excellent "how to" on THT (with pics!!) on re-building the helm.  http://www.thehulltruth.com/boating-for ... -pics.html
January 27, 2013, 07:01:15 PM
Reply #35
« Reply #35 on: January 27, 2013, 07:01:15 PM »
Damn, CB, I HATE the search function on THT...
January 27, 2013, 07:07:15 PM
Reply #36
« Reply #36 on: January 27, 2013, 07:07:15 PM »
Save it from DT when he used it.
It's in our Resource forum. Makes for an easier find.
Thanks DT. :thumleft:
