270/281/286/ 290 XF/Osprey Owners Group
nuttin fancy
Topic: nuttin fancy (Read 1240 times)
May 04, 2012, 03:32:42 PM
Read 1240 times
Hawg Hunter
nuttin fancy
May 04, 2012, 03:32:42 PM »
nuttin fancy wanted the teak plastic stuff but not for $ 480 had to do with the plain ole stuff
Capt, Richard "DUKE" Bowen
Conyers Ga
1988 290 Aquasport XF
May 05, 2012, 10:12:40 AM
ceejkay
Re: nuttin fancy
May 05, 2012, 10:12:40 AM »
ok, looks pretty cool.. but what in the heck is it or where is it going?
May 05, 2012, 12:13:08 PM
Rigging Master
Re: nuttin fancy
May 05, 2012, 12:13:08 PM »
Yes, Duke, explain. V-Berth liner?
May 07, 2012, 03:29:20 PM
Hawg Hunter
Re: nuttin fancy
May 07, 2012, 03:29:20 PM »
My mistake fellas yes the cabin in the 290 here is a before pic
Conyers Ga
May 07, 2012, 03:31:12 PM
Hawg Hunter
Re: nuttin fancy
May 07, 2012, 03:31:12 PM »
still gotta do some trim work from deck to the bottoms of bunk
Conyers Ga
May 07, 2012, 04:06:47 PM
Global Moderator
Re: nuttin fancy
May 07, 2012, 04:06:47 PM »
OK I see. You installed a new pie plate.
Floor looks good too.
May 07, 2012, 05:50:16 PM
Hawg Hunter
Re: nuttin fancy
May 07, 2012, 05:50:16 PM »
Yea do you see I had to fit a round 8 inch plate in a 10 inch square hole , It did have me lil confused there for a minute
Conyers Ga
May 07, 2012, 09:25:06 PM
ceejkay
Re: nuttin fancy
May 07, 2012, 09:25:06 PM »
looks good duke..
May 08, 2012, 05:15:36 AM
Re: nuttin fancy
May 08, 2012, 05:15:36 AM »
Nice work on the wood. The vinyl floor looks good too. Are you going to use vinyl cove base around the perimeter?
May 08, 2012, 08:15:24 PM
Hawg Hunter
Re: nuttin fancy
Reply #9 on:
May 08, 2012, 08:15:24 PM »
Havent figured it out yet , thinking of oak trim ? something i can screw too because there is nothing square anywhere in there i might have to fidge here and there to make it fit
Conyers Ga
May 09, 2012, 05:21:18 AM
Re: nuttin fancy
Reply #10 on:
May 09, 2012, 05:21:18 AM »
Cove base will be the easiest, will flow with the inconsistencies and help to seal off the floor. Attaches with a little mastic - the base board area is seldom scutinized and this will give it a finished look easily.
http://www.tools4flooring.com/vinyl-wall-base.html
nuttin fancy
