Author Topic: the 245 osprey  (Read 791 times)
May 19, 2005, 05:39:36 PM
Read 791 times
Jim Casey
the 245 osprey
« on: May 19, 2005, 05:39:36 PM »
I am looking at a 245 osprey w/250 hp johnson ocean runner t-top and trailer with mics. electronics all 1998 year model and was wanting any info about this setup i can get the asking price seems to be low @ 17,900 the motor has about 600 hours on it and compression check is good. thanks for any and all help Jim Casey
May 20, 2005, 11:57:43 AM
Jerry-rigged
« Reply #1 on: May 20, 2005, 11:57:43 AM »
seems good to me - the ocean runner is driving the price down, I bet.  It is a carb'ed 2 stroke.  Very reliable, but VERY thirsty.
Did you check the NADA?
Jerry
May 20, 2005, 03:28:44 PM
Anonymous
« Reply #2 on: May 20, 2005, 03:28:44 PM »
yea I did and it lists @ 27,000 for average and this boat is definatly at least average.
June 24, 2005, 10:29:31 PM
StevieT
« Reply #3 on: June 24, 2005, 10:29:31 PM »
I have a 98 245 Osprey and here is a little history on it.
Purchased new 4/99 with a 225 Optimax, trailor, Teetop and electronics box for $34800.
In 2001, it was returned to Sarasota to have the deck pulled and stringers/supports installed under and in front of the Teetop. Seems they used the same hull as the cuddy model. ( NO SUPPORT OR STRINGERS where the cudy would have been hence a spungy deck)
Last month the deck under and behind the teetop became spungy and had 1/2" +- of give. I contacted Aquasport and they sent me to a fiberglass outfit in Miss. The deck is being pulled as we speak as the Balsa wood was rotten and will be replaced with a high density foam to prevent any further need for repairs. I HOPE!!!
When it leaves the fiberglass shop, it goes to have twin 150 Yamaha 4 strokes installed.
Optimax is outta here! Nothing but problems.
Stevie
