Author Topic: 1978 19'6" open fisherman  (Read 1391 times)
December 26, 2006, 02:50:15 PM
Read 1391 times
skinnywater
    • http://www.toughtackle.com
« on: December 26, 2006, 02:50:15 PM »
Hi,
I have a 1978 19'6" open fisherman, and I was wondering if anyone out there can give me an idea on the height from the top bow to the waterline? I want to buy a bow mount trolling motor for her, but I don't have enought time right now to get her in the water to get a measurement. Anyone have an idea?
I found a great deal on a trolling motor with a 52" shaft, but I'm not sure if it will be long enough.
Please help!
The worst day fishing is better than the best day at work!!
December 26, 2006, 05:06:02 PM
Trolling Motor
« Reply #1 on: December 26, 2006, 05:06:02 PM »
52" is right on the line between enough and not enough.  The only way you will know for sure is to try it.  I tried a 54 MotorGuide on my 22-2CCP and it was a little short.  My current MinnKota 70AP has a 60" shaft and works great.  Also the plastic (composite) shaft on the MinnKota is a lot lighter up and down that the 54" MotorGuide.
If you are looking at a MotorGuide, make sure you also get the Big Gator or Great White mount - the regular Gator does not work well with shaft lengths over 50".
Also, consider how the motor is going to reach over the "lip" of the bow.  I worked with this a bit and wound up using the big MotorGuide quick disconnect slide-type mount with holes for stowed and operating positions.  This gets the motor back and prevents dock (or whatever) damage when the motor is not going to be used.   A quick disconnect pin and a clamping screw keep the motor in the desired location.
Here's how it looks moved back in the stowed position:
Here it is moved forward and deployed:
[/b]
I move it forward for the first use on each trip, then leave it in that position until the end of the day, or if I just want to move it back to get it out of the way.  Of course, you can also just take the whole thing off if you want - a nice security feature!
Don't forget the wiring details either - 4 or 6 gauge from the batteries to the motor, with a 50 or 60 amp breaker!
Hope this helps   :wink:
December 27, 2006, 09:28:03 AM
skinnywater
« Reply #2 on: December 27, 2006, 09:28:03 AM »
Thank you so much for taking the time to respond. You're a life saver! :D
February 05, 2007, 08:47:21 AM
skinnywater
« Reply #3 on: February 05, 2007, 08:47:21 AM »
I see what you mean about getting the engine out and over. Where did you buy that slide mount?
