Perfect timing for my question Bruce-
I took the deep dive on my boat cover 4 years ago. I had a custom cover built for the 22-2, over the T-top, motors and about 12" down the gunnels, draw string around the perimeter plus tie-downs. Sunbrella material. Really nice cover to the tune of $1200. All of the areas subject to chafe were reinforced with heavy clear plastic material (vinyl) and stitched into the fabric on the inside. Typical annual cleaning is with a very low pressure, pressure wash to remove pollen and dirt and then 1 1/2 gallon of 303 in light coats. Starting to see leaks in the reinforcment areas, starting to see elongation of the stitching to the point where heavy rain is passing through. Is there any localized water repellent treatment I can do to stop the leaks. The holes are maybe a 1/32 in diameter is some areas. Just enough to let a pounding rain in. Normal light rain is no problem and stays dry. Thought about silicone, petroleum jelly, something that will stop the leak without damaging the Sunbrella or stitching. I really try to take care of this cover; its been excellent otherwise with no other deterioration. Any advice? Thanks Bruce.
Farley
