It's built back really strong! I'm really happy with how its turned out structurally so far. I finished tabbing the inside of the stringers and the thru drain at the back of the stringers so I Started to fill the stringers with foam on Saturday. It started to rain and cool down so i put foaming on hold till this weeks warmer weather.
Rickk, the hull side coring added less than 120lbs to the hull weight .....1 pail of resin (45lbs), about 15-20lbs in 1708 glass (one layer), I would guess about 15-20lbs of foam sheets (scrimmed and scored), and about 30lbs of Arjay 4001 Core Bond.
