Aquasport Mechanicals - things that need a wrench, screwdriver or multimeter > Electrical
battery recommendations
(1/1)
Cpt. Beyond:
hello, i plan to grab a pair of AGM batteries for my 17' osprey. any reason i should consider lithium batteries? seeing if anyone has had any good experiences using lithium boat batteries.
Capt. Bob:
What I know about Li-ion batteries is that they are lighter in weight and more costly. Your outboard charging system "might" not be the best way to keep them charged. Still, they are used by a lot of RVers and blowboaters using solar to charge or dedicated chargers.
nestorpr:
What Capt. Bob said, do some research and make sure it won't void your engine's warranty (if any). Lithium batteries require a completely different charging algorithm and most existing engine charging systems cannot charge them correctly.
Cpt. Beyond:
ok, considering im about to attempt to revive a 2 stroke 90hp merc from 1995 and my 2nd option is a 90hp merc from 2004 id say lithium is out of the question. AGM it is. thanks for the info
Ulysses485:
I did some pretty extensive research about a year ago on this and my findings were that if money is no object, Lithium Ion will be the battery of choice. However, the primary use is on performance race boats where weight is a factor. AGM is great battery for a little longer life expectancy and less maintenance. However, I believe that where the decision needs to be made is how the boat is maintained and used. If the intent was to keep it regularly on a quality trickle charger ALL THE TIME, a flooded lead acid battery will do great and could give you 3-4 years. They are easy on the wallet. However, the problem lies when a flooded lead acid battery sits for long periods of time without maintenance (charging). It is at this point that an AGM or Lithium will really leap ahead of a flooded lead acid battery. I see it similar to a car battery that is typically a flooded acid battery which is constantly kept topped off (commuter/daily driver car). Ever let a car sit for months at a time? The battery will typically deteriorate rather quickly. However, in the marine world we are really talking about two types of batteries....a starting battery (which needs constant charging to keep it topped off) and a marine deep cycle ("house") which can go to full depth of discharge (drain) much more regularly without damaging the battery. Speaking of depth of discharge, you will see 50% "usable battery" with a flooded lead acid, 80% with AGM about approximately 80-95% with a lithium Ion. On a side note, I have changed to AGM batteries every time in my vehicles (for the past 15yrs) and find that I sell the vehicle before the AGM battery dies on me.
