Aquasport Model Rebuilds, Mods, Updates and Refreshes => Osprey Style Hull Rebuilds => 22-2 Rebuilds => Topic started by: Caldozx6rr on June 11, 2020, 11:08:08 AM
Here is what im starting with.
(http://www.classicaquasport.com/gallery/data/500/25F5B875-8800-44E6-BC50-47066B91631E.jpeg) (http://www.classicaquasport.com/gallery/showphoto.php?photo=20215&title=25f5b875-8800-44e6-bc50-47066b91631e&cat=500)
Getting some first time glass work in!
(http://www.classicaquasport.com/gallery/data/500/IMG-3278.jpg) (http://www.classicaquasport.com/gallery/showphoto.php?photo=20316&title=78&cat=500)
(http://www.classicaquasport.com/gallery/data/500/IMG-3279.jpg) (http://www.classicaquasport.com/gallery/showphoto.php?photo=20317&title=78&cat=500)
(http://www.classicaquasport.com/gallery/data/500/IMG-3281.jpg) (http://www.classicaquasport.com/gallery/showphoto.php?photo=20318&title=78&cat=500)
A few air bubbles to fix
Two layers of 1708 inside the 2" lip of the old transom to build it up level with remaining layers. Three layers over that tabbed at 4", 8", and 12". Next step is to cut the coosa is there an easy way to "stencil" the current shape of the transom?
Good progress.
Before you get to the next step you might consider adding a PVC pipe to the transom before you move the low point too far forward.
Also, when you take a picture with your phone try to remember to hold the phone horizontal so the lens is to the left. That will make the pic orientation marker correct for forums. I rotated the pics in your gallery.
Thanks Rick yeah I realized the phone thing after! I plan on putting the pvc in today or tomorrow. Thanks for the reminder
(https://classicaquasport.com/gallery/data/500/IMG-3659.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21059&title=stringers-2f-tank&cat=500)
(https://classicaquasport.com/gallery/data/500/IMG-3657.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21057&title=stringers-2f-tank&cat=500)
Getting there!
Looks good keep progress going. How much foam did you end up using in your stringers? Hope I ordered enough. What size tank did you end up getting ? Good job
I hope you allowed 2% for the gas tank to grow once it gets gasoline in it. That's 2% in every direction. Progress looks good.
I forget the exact amount of foam used but it was around 800$ worth. And the tank is a 55 Gallon tank from Moeller. Thanks Rick it’s still just sitting on top of the foam. What are the consequences of not allowing the expansion space?
They say the tank could crack or crack the surrounding area.
Anyone know if a Bobs 14inch offfset jackplate would work? Not a huge fan of the cost of a Porta-Bracket.....
The problem with a jack plate is they don't raise up enough for you to tilt the engine up and over a full transom.
I looked at that option when I did mine but ended up finding a used porta bracket instead. I was able to clean it up, replace a few things and wire it up for less than the cost of the 14" jackplate. Bob's also makes additional spacers if you need a little more clearance but that additional cost just made the porta a better choice for me.
Thanks Mike I think I’m going with a porta bracket.
(https://classicaquasport.com/gallery/data/500/deck13.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21592&title=deck13&cat=500)
(https://classicaquasport.com/gallery/data/500/deck1_5.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21593&title=deck1-5&cat=500)
(https://classicaquasport.com/gallery/data/500/deck22.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21594&title=deck22&cat=500)
(https://classicaquasport.com/gallery/data/500/transom16.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21588&title=transom16&cat=500)
(https://classicaquasport.com/gallery/data/500/transom23.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21589&title=transom23&cat=500)
(https://classicaquasport.com/gallery/data/500/transom33.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21590&title=transom33&cat=500)
(https://classicaquasport.com/gallery/data/500/console6.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21591&title=console6&cat=500)
Lots of progress. Good for you. :salut:
Wow! Awesome progress. The boat is looking great.
Thanks y'all, next week it gets primed! Starting to see the light at the end of the tunnel.
(https://classicaquasport.com/gallery/data/500/paintboat.JPG) (https://classicaquasport.com/gallery/showphoto.php?photo=21810&title=fresh-paint&cat=500) :danceSm:
Sorry for the pic orientation
(https://classicaquasport.com/gallery/data/500/leaningpostmotor.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21809&title=lieaningpost-2fmotor&cat=500)
SO CLOSE! Only a matter of days now!
(https://classicaquasport.com/gallery/data/500/bracket1.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21808&title=porta-bracket&cat=500)
Sweet! 🤑
Lots of goodies there to play with. :cheering2:
Looks like it’s going to be a sweet ride! Congrats!! It’s nice to start getting deliveries and the new shines stuff starts going on. :))
Congrats!
One thing I didn't realize is just how long this process would take. Its almost exactly a year since I started this after saying ill get it done in just a few months........I couldn't have been more off haha. I have a good dude doing the work and he's killing it!
(https://classicaquasport.com/gallery/data/2/final.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21817&title=final&cat=2)
We have a boat!! Holy cow not too long before its in the water! :woohoo: :singing:
Nice - love the color. :thumleft: :thumleft:
Lookin' good. :great02:
Coming along really nicely!! Let’s see some shots of the inside :))
(https://classicaquasport.com/gallery/data/500/finaldeck1.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21823&title=finaldeck1&cat=500)
(https://classicaquasport.com/gallery/data/500/finaldeck2.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21824&title=finaldeck2&cat=500)
(https://classicaquasport.com/gallery/data/500/porta2.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21827&title=porta2&cat=500)
(https://classicaquasport.com/gallery/data/500/porta1.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21826&title=porta1&cat=500)
Wow looks really good! What color is the cap? Looks to have a cream tone.
Gotta be getting excited now.
The color of the cap is Cloud White the interior walls are a tad cream to avoid glare...
(https://classicaquasport.com/gallery/data/500/sideppbracket.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21830&title=sideppbracket&cat=500)
(https://classicaquasport.com/gallery/data/500/rearpp.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21829&title=rearpp&cat=500)
Getting there now! It does seem like more little things pop up but nothing major!
One more thing the Stars and Stripes blue that was used changes color with every picture....,
Woah! Now your cookin! Cloud white is a nice color! I’ve looked at it before I like it! I agree with the cream interior. Coming together nicely! Thanks for sharing!
That Powerpole seems taller than the garage door
Boat is looking good. Love the colors. That thing will fly with that 200. I’ll be interested in a performance report. I considered the Merc v6 for my boat, but went with the tried and true 150.
Yeah im most curious about how it performs too its about two weeks away from hitting the water I will report back soon!
(https://classicaquasport.com/gallery/data/500/finaldeck.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21927&title=finaldeck&cat=500)
(https://classicaquasport.com/gallery/data/500/finalconsole.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21926&title=finalconsole&cat=500)
(https://classicaquasport.com/gallery/data/500/finalsoleandlw.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21929&title=finalsoleandlw&cat=500)
(https://classicaquasport.com/gallery/data/500/finalsideview.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=21928&title=finalsideview&cat=500)
Beautiful!
Sweet!!
Great Job! I like the way the black porta bracket makes the motor look like it is levitating behind the transom lol
(https://classicaquasport.com/gallery/data/2/realfinaltopside.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=22036&title=realfinaltopside&cat=2)
(https://classicaquasport.com/gallery/data/2/realfinalconsole.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=22034&title=realfinalconsole&cat=2)
(https://classicaquasport.com/gallery/data/2/realfinalside.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=22035&title=realfinalside&cat=2)
All done and water tested and got a surprising results. 55mph @ 5500 rpms. It jumps like a jet ski its pretty impressive.
Sounds like it'll be a lot of fun for you and your family.
Wow, turned out great!! Those are some pretty impressive numbers. Sounds like she is dialed in. What prop are you turning?
Merc Rev 4 19 pitch
Congrats on completing the rebuild . Great looking boat . Clean and simple. I like the webbing finish along the inside im a big fan of the webbing finish if you dont believe me ask tampa bay mike , i have it down on my idea paper for my 200 that one day i will hopefully finish. Good luck with the new rig now go put some blood and scales on the deck
Yessir tahnk you going to be in the keys this weekend! Webbing > Sanding....haha and it looks good
(https://classicaquasport.com/gallery/data/500/keysttop.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=22070&title=keysttop&cat=500)
The boat did well 20 miles offshore from Marathon! Found some Mahi and Tuna
(https://classicaquasport.com/gallery/data/500/finalseatforward.jpg) (https://classicaquasport.com/gallery/showphoto.php?photo=22069&title=finalseatforward&cat=500)
Had some custom upholstery work done to complete the t-top!
Awesome! The vinyl looks great, im glad you were able to get some blood and scales on that deck. Sounds to me like you broke her in right.
