Author Topic: Replacement Courtesy Lights  (Read 985 times)
June 08, 2016, 10:25:58 AM
Read 985 times
MPKehoe09
« on: June 08, 2016, 10:25:58 AM »
I'm looking to replace the courtesy lights that are along the bottom of my center console (1998 175 Osprey); see attached image.
I found a light that seems identical in proportion (referred to as a Livewell or Baitwell Light), but once it was delivered, it was about 1/3 of the size of the original.
Has anyone found a good LED replacement light/housing? The light is about 2.25" in diameter.
I rarely use the boat during the dawn/dusk, so I am not looking to spend a lot of money on these lights, as they will get limited use.
Thanks in Advance,
MK
April 25, 2017, 08:15:27 AM
minionsram
Re: Replacement Courtesy Lights
« Reply #1 on: April 25, 2017, 08:15:27 AM »
http://www.academy.com/shop/pdp/marine-raider-led-companionway-light#repChildCatid=1010552
I used these and was able to put my stainless covers back on it.
April 25, 2017, 09:18:26 AM
« Reply #2 on: April 25, 2017, 09:18:26 AM »
Are you looking to replace because of damage or rather switching to LED?
I would guess the lamp is a festoon style bulb?
Maybe switch out the incandescent for a LED lamp? :ScrChin:
Something like this:
https://www.superbrightleds.com/cat/festoon-series-bulbs/
Good Luck. :thumright:
April 25, 2017, 09:38:39 AM
« Reply #3 on: April 25, 2017, 09:38:39 AM »
X2 for Bob - I replaced the bulbs with LED festoon bulbs and they work great.
September 23, 2019, 02:19:08 PM
TopherMichael
« Reply #4 on: September 23, 2019, 02:19:08 PM »
I checked the 3 bulbs on my boat and the bulb number is no longer marked on the bulb. Does anyone know what the stock bulb number/size is?
1999 Osprey 175
December 30, 2019, 04:23:43 PM
